Cryorig A40 Ultimate AIO Liquid Cooler
adrielx
Hi all,
My Cryorig A40 Ultimate AIO Liquid Cooler seems to be emitting some noise from the radiator. The noise is especially loud when just booted up and will subside to less audible level after 2 to 3 mins.
Is this normal?
Just booted up noise level: https://youtu.be/et2wLzBgE3c
After 2 to 3 mins: https://youtu.be/9hkvX_veTFk
the noise is actually causing my case to have some vibrations.
Rig setup: Radiator mounted to roof of NZXT H440 with fans below in push config. Airflow fan mounted on heatsink.
adrielx
remounted the radiator as advised by Corbell. I also relocated one of the HDDs which was in light contact with 1 of the hose. the noise disappeared after that.
now left with a pulsating vibration which can be felt at the sides and top of the case. think this vibration originates from the pump doing its job.
So far pretty happy with the result.
