Custom build rig to work as NAS?
moodless
Hi guys,
Can i check if there is any recommendations on building a custom rig to double up as an NAS?
If I'm not wrong, some motherboard out in the market does support raid? Or would it be more advisable and make sense economically to just buy one ready made in the market?
I'm thinking of using the FreeNas8 software.
Thanks in advance!
jtjt00
You got to look at:
1. Price ready made NAS vs self built
2. Power consumption
3. Maintenance
4. Data recovery in event hardware failure.
t258jgn
Lian Li PC-Q26 Mini-ITX HTPC Case (Black)
or
Silverstone DS380 Mini-ITX Case
sst-ds380-05.jpg~original
SNAG
Depending on your requirements, I strongly suggest getting A HP Microserver Gen 8. Cheap and gets the job done, processing power is strongly expandable as the CPU is socketed.
But it'll take time for the customization, and depending on the software, the costs can be high versus a ready-made NAS (freeNAS to Windows Server).
alifffresto
Hi guys,
Thanks in advance!
Moi also wanna build one in the upcoming month. planning to use the e3c226d2i.
moodless
I'll be using it mainly as a file server, media server and probably configuring VPN and FTP functionality..
moodless
You got to look at:
3. Maintenance
TBH I am quite noob in terms of NAS references. Any advise?
alifffresto
I am in same boat as you before.... if you only pair it with that better get this board from asrock C2550D4I or C2750D4I
now i still researching to get which board C2550D4I or C2750D4I or SUPERMICRO MBD-X10SDV-4C-TLN2F-O
they say freenas eats ram, so im actually re-considering the e3c226d2i too. if 16gb not enough then i'll be in trouble.
The C2550D4I that you suggest looks great imo. Not sure with supermicro board coz price is quite steep =:p
wideCDMA
if you are using ZFS then it need more ECC ram something like 1GB = 1TB.... you still can use normal ram or 16GB am sure the performance can fight or much better than Branded NAS ..
C2550D4I cheap but amazon do not shipping to SG only the C2750D4I ship to SG but the price very expensive...
t258jgn
Lian Li PC-Q26B Mini-itx Aluminum Case (Black)
Asrock E3C226D2I Intel C226 Skt1150 Mini-ITX Server MoBo (Bulk Pack)
Kingston KVR16LE11/8 16GB (2x 8gb) DDR3 1600 Unbuffered ECC CL11 1.35V w/TS
Seasonic X-650 650W Full Modular 80+ Gold
Only $1k
haodede
Suspended
TS, allow me to hijack your thread abit.
Can freenas and pfsense (router) run on the same machine through vm? Is this setup advisable?
Op_Valkyrie
U can do it... However from a system and security standpoint I would advice these two services to be isolated via VM or bare metal as usually we wouldn't want to compromise security - more things running open to more vulnerability. Even jailing them is still not safe IMO...
haodede
Suspended
Thanks for the advise.
xieyuqi
What do you think of Lian-li PC-Q26B with Gigabyte GA-Z170N-wifi?
Am I right this mitx motherboard can support 10x SATA and 1 x M.2?
Anyone know which shop sells PC-Q26B?
