custom gaming rig help pls :(((
rias92
so yea my asus g750 is probably going to 'rosak' soon and i dont really know how to assemble a gaming rig or even know if they are compatible. Is there any friendly shop in sg that allows me to pick and then they help me fix it or is that too much to ask?
Koenig168
Just post your budget and what you intend to use the rig for. A lot of guys here will be happy to provide you with suggestions for a build.
IceCreamPoop
There are a metric butt ton of shops like that actually(just go SLS). Only condition being you buy a few stuff from them. If you only looking to buy for a graphic card they will probably not going to bother installing it for you. That aside if you are only replacing your graphic card its quite easy to do so actually.
Agreed ^ If you only looking to replace your graphic card maybe post your current build as well :)
rias92
What would be a good price range? I intend to use it for mostly steam games like csgo and gta v on medium-high settings . Anything less than 1k would be nice
mib500
you need os, keyboard, monitor?
mib500
CPU+MB: Intel Core i5-4460 + ASRock H81M-HDS R2.0 @ $294
RAM: Crucial DDR3-1600 CL11 8GB @ $61
GPU: Zotac GTX 960 2GB Twin Fan OC @ $295
SSD: Transcend SSD370S 256GB @ $138
HDD: Western Digital Blue 1TB @ $76 (PC Themes)
PSU: FSP Aurum S 500W [80 Plus Gold] @ $89
CASE: Cooler Master N200 @ $55
Total: $1008.00
Buy at Tradepac or PC themes.
Try to bargain for further discount.
