Custom PC build. Need advice.
TheKiwiHead
Hey guys! This is my custom pc build which I'm intending to purchase at either stores in Sim Lim or Funan.
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($319.98 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Amazon)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($134.99 @ Amazon)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($45.86 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($67.99 @ NCIX US)
Storage: Samsung 840 Series 120GB 2.5" Solid State Disk ($91.78 @ eCost)
Video Card: PNY GeForce GTX 670 2GB Video Card ($299.99 @ NCIX US)
Power Supply: Antec High Current Gamer 620W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($69.99 @ NCIX US)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($22.98 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
Total: $1173.52
Any recommendations of which stores to get? Any good changes to my specs?
Thanks :D
Total: $1173.52
Thanks :D
1) Are you overclcoking?
2) What are you using it for? Just gaming, or video ediitng, etc..? And how often and intensive?
3) The prices doesn't seem to be in SGD...
TheKiwiHead
1) I might be over clocking.
2) I'm using it for gaming, photoshop, and video editing and homework :D. Maybe twice a day? Not really sure.
3) I got these prices from pcpartpicker.com :D It's in USD. I'm wondering if I can get it in SG for similar prices.
1) Okie... (=
2) What video editing software are u using?
3) I don't think so =(
nipp0n
What is your budget?
CPU & Mobo: i7-3770k & Asrock Extreme 4 @ $609
CPU Cooler: CM Hyper Evo 212 @ $59
Ram: G.Skill 1600mhz 2x8GB @ $102
ODD: HP DVD RW @ $25
HDD: Western Digital Blue 1TB @ $90
SSD: Plextor M5P 128GB @ $155
Case & PSU: NZXT Phantom 410 @ $155
PSU: Corsair HX650W @ $159
GPU: Gigabyte GTX 670 2GB Windforce @ $589
OS: Windows 7 Home @ $120
Total: $2063
Buy and build at PC Themes. Pretty close to the rig you wanted.
nipp0n
Sony Vegas.
My budget is around 1.3k SGD without gst.
CPU & Mobo: i5-3750k & Asrock Extreme 4 @ $475
Case: Sharkoon T28 @ $89
PSU: Seasonic S12 520W @ $78
GPU: Powercolor 7850 PCS @ $279
OS: Windows 7 Home @ $103 (Tradepac)
Total: $1300
Buy and build at PC Themes except for OS.
Sony Vegas favour AMD GPU due to AMD OpenCL framework.
http://www.sonycreativesoftware.com/vegaspro/gpuacceleration
