Custom Rig. Please advise.
Ian
Will the offer go away soon? Advisable to buy now and use later??
Not sure if i need one cus I'm intending to change my win7 laptop to a new desktop this black Friday.
BTW what is office 2016 ah?? To be released next year??
Sent from OnePlus A0001 using GAGT
Just purchased Microsoft Office Professional Plus 2016 yesterday.
CD Key given works great and installed from the given download link.
harky
If I purchase a Win 7 key and upgrade to Win 10, in future I do a fresh install do I have to install Win 7 first b4 doing Win 10 or I can just do a direct Win 10 install.
In future, if you need to format and install, can direct install win 10 .
Make sure your first install, you must activate it so it tag to your MB
Sent from Samsung SM-N920I using GAGT
intrance
Hi guys..
As the recommended Gigabyte H97N+Wifi might out of stock, I need few alternative for motherboard.
Im getting a new desk and it should has enough space for m-atx casing.
Pls recommend me
1. few motherboards - mini-itx/m-atx for me to choose (again, in case out of stock)
2. WIFI Card.
Many thanks in advance.
mib500
Hi guys..
Pls recommend me
2. WIFI Card.
you can consider H97M-itx from asrock or Asus H97-PLus or Z97-Pro... all come with wifi...
intrance
Many thanks bro.. will have a look..
Do you think having a standalone WIFI card is better than WIFI intergrated onto motherboard or vice versa?
initially looking for MB with WIFI because of limited expansion slots in Mini ITX casing.
Now I can choose m-atx casing with extra slots..
Guojing88
OS: Microsoft Windows 7 Professional SP1 64-bit Product Key [OEM] @ $28 (Reddit)
May I check what does this mean, how does one purchase this at $28 from Reddit?
mib500
and from singapore they prefer paypal. so make sure everything is prepared. read the instruction carefully.
mib500
im not really good at wifi.. but if now you can consider MATX board better go standalone card... as long you have budget... but why don't use lan cable much better?
intrance
Thanks for the advise.
My fibre router/ modem box is located on the living room. Impossible to run any cables unless i drill holes on some of the walls.
And also i want to connect to my printer via wireless. Printer is in my son's room..
enenyi
Best solution is to run LAN cables along trunking to your room. That would mean some drilling and DIY to do, but the reward is full speed of whatever broadband plan u paid for.
Alternative solution is to run homeplugs. Tradeoff is u only get 50-70% of broadband speed. But still better than wifi which sometimes varies from 5-75% of broadband speed.
mib500
yeah best is using lan cable... but if you really don't have a choice best is buy standalone wifi card..
