Custom water cooling
shadey
What is the best brand to consider for the watercooling parts. :)
Easiest and most available I'd say are the Corsair HydroX and the new Themaltake Pacific series. Barrow/Barrowch are easy to order online
Trans-Am
maintenance wise, how is it?
How long need to change the water?
Sent from A universe Where pink PWNED everything using GAGT
shadow84
If no foreign particles, yearly change is fine. I had changed my clear coolant after 1+yr and it is still looks clear, no particles inside (provided previously got wash thoroughly).
Trans-Am
So I need to disconnect all the tube and wash every year?
shadow84
Tbh, i have not done that for a long long time although i change blocks once every 2 yrs or so. As long as there is no visible algae, i believe there is no need to be alarmed. U can strip all and clean or just leave it be. If using distilled water, just drain and pour new batch. If with coolant, might wan consider longer maintenance period as it is ex.
wiwi
my h100i aio is 6 years old. Time for a change? My cpu hovers around 60C when i game though. idle @34C+-
