D size battery for gas stoves
derrickgoh
My battery went flat so I bought new D size Energizers. Got a shock when it would not fit into the battery compartment. I put the old battery beside the Energizer and turns out not all D size batteries are the same! :s8:
I asked my contractor and he said Panasonic or China brand D size batteries are a bit shorter. Anyone know where I can buy Panasonic or China brand D size batteries? Or does anyone know which brands are so called China brands?
kimsim
Suspended
Huh what is ur gas stove brand?
How come were out of standard size?
tekster
D size all the same la. Shorter means C size lo.
U can use AA batteries then buy C or D adaptors leh.
derrickgoh
I'm not that toot lor. C is C. D is D. C is significantly smaller than D but as you can see in the pics, the Energizer D is only a tiny bit longer than the other 2.
The stove says Schott Ceran. Supposedly some North American brand according to Google.
