- Mar 22, 2011
I don't think StarHub Prepaid has network lock function.
oh well. Guess if that is the case, have to set network to manual to China telcom
Recently, I travel to China, Macau, Hong Kong and US.
I used WeFlySim for internet data.
You can purchase it from Qoo10.
Advantage
One SIM card for worldwide. My phone will auto switch to local telco for internet.
Weflysim SIM card has no expiry date
Can use Google services, Facebook, Twitter, WhatsApp in China (not require VPN)
The WeFlySIM support is always online (via WhatsApp).
Can top up the data while on the go
Disadvantages
No local phone numbers.
- Some places that provides free WiFi, they need a local phone to receive SMS to activate the free WiFi.
- my local contact reaches me via WeChat or WhatsApps
No way to check data usage online.
- have to check using phone counter, but may not correct as telco may calculate data usage differently
word of caution for SingTel users ... if u do not need overseas roaming from SingTel, besides unsubscribing or terminating AutoRoam, you should also cancel the "Pay As You Roam" service
if you just cancel AutoRoam, you will then be charged under Pay As You Roam which carries exorbitant rates ... eg $35 for 1 MB (yes 1 MB data)
I was using Starhub HappyRoam, turned on roaming and was also charged under SingTel Pay As Your Roam
StarHub postpaid has one of the best roaming plan at $15/+2gb/30 days/any operator. Pretty no brainer to me.
Sent from Sony Xperia XZ2! using GAGT
Wanna ask... I just jumped ship to Starhub and going to Taiwan for 6 days.
https://www.starhub.com/personal/mo...g/postpaid-roaming/data-plans/datatravel.html
The datatravel is 1GB for $5 over 3 days. It is possible to enable 1GB for first 3 days and another 1GB for 4rh to 6th days?
Thanks.
U need to buy before current data expire. StarHub follow the timing that you activate.
Thanks, just managed to locate the information from SH FAQ.
So if I departure on 1 Aug 6am and I purchase 2x "1gb for 3 days" it should expire at 7 Aug 6am, correct?
Ya. They will send u a sms on which date and time expire.
