I have decided to start one more RSP with another ETF, while keeping (and not terminating) the existing RSP.
Should be Ok for the Multiplier right?
May I know how to purchase RSP ? Can do online or must go bank to purchase?
If you setup a RSP and terminate (<12 months), you cannot setup the same ETF again.
Got the reply from DBS:
Can do via dbs ibanking
So for those with only salary credit+spend dbs cc, better to move elsewhere if got more than 25k right?
What will be other options? Ocbc 360?
But I don't have ocbc cc...
Sent from Home using GAGT
I moved a portion to CIMB. Min 10k placement, you get 1.85% for 12m tenure, which is still acceptable for me.
If I am intending to start multiplier with cancercare and POSB Investsaver together, am I right that these are the sequence of steps to coordinate since the insurance cat only start 1 month after you applied whereas the investment cat starts effected in the month that you applied.reposting my plan..
strategy will be the sequence below:
- start RSP ETF A before 15 Feb 2020 (effective till Jan 2021)
- stop RSP ETF A after 15 Jan 2021
- start RSP ETF B before 15 Feb 2021 (effective till Jan 2022)
- sell ETF A latest by Jul 2021
- stop RSP ETF B after 15 Jan 2022
- start RSP ETF A before 15 Feb 2022 (effective till Jan 2023)
- sell ETF B latest by Jul 2022
- repeats the same ...
of course you can choose to buy ETF C instead if the price points are not good to sell when the time comes. But really, i think we are thinking too much into the future where the terms are not constant.
I think OCBC 360 will be better for those who only can hit Salary credit + 1 category (credit card spend but no minimum amount) for DBS Multiplier.
DBS Multiplier
Salary credit + 1 category (credit card spend but no minimum amount) - 1.55% to 2.08% depends on eligible transactions per month (cap at $25,000)
OCBC 360
Salary credit - 1.2% (first $35,000) and 2.0% (next $35,000)
Is there a limited list of UT or ETF that is eligible for multiplier or all funds can be counted?
1) In Jan 2020 - Apply for CancerCare that will be effective in Feb 2020
2) In Feb 2020 - Apply for POSB Investsaver that will be effective in Feb 2020
3) Redo everything in Jan 2021 - after 12 months for the next wave till 2022
Correct?
All eligible but only 4 are under RSP (min $100)
Correct?
For 2, rmb to do it before 15th Feb for it to be counted.
For 3, you need to buy another rsp for it to count. Insurance can terminate and buy the same one.
