What are the 4 funds ?
Singapore Equity ETF
1. Nikko AM Singapore STI ETF
SGD Fixed Income ETFs
2. ABF Singapore Bond Index Fund
3. Nikko AM SGD Investment Grade Corporate Bond ETF
REIT ETF
4. Nikko AM-StraitsTrading Asia ex Japan REIT ETF
Yes it is counted as income. But u need min 2k income per mth.
yep. is more like a supplementary high interest savings account without a lock in. cause uob/ocbc all requires salary. whereas DBS doesn't.Yes it is counted as income. But u need min 2k per mth across all categories.
as long as there is $1 in income that goes in a mount, can always use other transactions for the higher income.
so just want to confirm if the interest credited from SSB is under the "CDP" or "NDIV" transaction code.
ah ok. so can use DBS and UOB as a combiUOB doesn't need income, it can be 3 GIRO bill payment with $500 minimum credit card spend.
Posted from PCWX using Mi 9T Pro
Yes. And in case you want to reuse one of the 4 funds, need to terminate and fully redeem the fund at least 6 months before your reapply the RSP for the fund again
Yes, only if you mean "cancel" as "terminate and fully redeem"Hey Trazora,
May I just double check on this please? The last time I did it was before SSB ladder was still valid. For me, I've previously did 12 months of ABF already, >6 months ago.
So to make it simple and just use ABF and Nikko ETF, to clock Investment category, I should:
1) Start Invest-Saver now for ABF, which will make me eligible from Mar 2020 - Feb 2021 (12 months)
2) Cancel ABF in Mar 2021, then open fund with Nikko ETF, eligible from Mar 2021 - Feb 2022 (12 months).
3) Cancel Nikko ETF, & start ABF again. Should not be an issue since ABF would have been closed for >6 months already.
Rinse and repeat. Hope I got it correct?
for the invest category, does it apply from the month of sign up, or only start from the following month?
I still have not received my multiplier interest this month..
Anybody facing the same issue?
When the new rate apply ah? Still got my usual amount this month.
Both need to setup own invest saver even the money deduct from joint account. This count individually.Hm... previously I did the ssb step in a joint account so both wife and me get the investment portion
So in the situation now , if I use the money from the joint account to investment in the monthly invest saver will we both get the investment category or need 2 separate person to do it ?
Thank you very much
Guess no choice have to do for both accounts
From the response on this thread I think most recommended is NIKKo sti etf
Any others which can also consider?
TIA
