DBS changed its Mutiplier plan
Potato_Wedges
Hi all,
I entered in dbs website multiplier account balance as 90K. Income, credit card spending and home loan total is at the 5k - 15k range. The interest works out to be 1120.55 which is only 1.25%.
Am i wrong somewhere?
You need another Cat to get the 2.4%. Best bet is investment.
Safest is RSP (Nikko AM Sti) $100/month.
Since you have 90K, another strategy is to buy a DBS/UOB lot ($21000) each month. Sell if the lot has capital gain. Repeat. Your interest jumps to 3.8%. :s12:
reddevil0728
1 lot = 100 shares now.
Extremme
In ibanking, there is a small average price below the number of units you hold.
So I started G3B in Feb at $100
Technically equates to $100 * 5 = $500
I see the average investment price of 2.74
Indicative price of 2.77
The Market Value is $497.06. In layman terms, MV is the column I shd be concerned abt right. If it goes above $500 then its considered a gain
So technically I did not gain right?
reddevil0728
if you want to be super accurate
Take the number of shares you get from each month, multiply by the unit price they indicated. sum it all up, divided by the total number of shares you have.
then go check SGX website for the share price of G3B
IcYFl4mEz
This month's purchase price for G3B is 2.7245.
So if your RSP is set at $100, you bought 36 units.
Total is 2.7245*36 + 1.11 + 0.82 =100.012, the value you see is based on current price.
before i submit, i took a photo its indicated unit price is 2.9031.
im not good at calculating... :s11:
TiedInsurer
DBS doesn't care when you submit. They will buy on the 15th. If you submit on 16th May, they will wait til 15th June, then they buy.
Extremme
if i have 1,100 in the multiplier account and I transfer $100 out, any penalty?
Davo23
dividends reclassified to Income, no more eligible as investment category.
If you invest using vickers yes
Ok got it. Thanks a lot guys!
Alphaen
I have applied for ETF RSP to boost the multiplier interest which deducts on 15th every month. But today I checked it still not registered under the Bank and Earn summary. option is still there to apply for investment category. Is there a step needed to link the RSP to my multiplier account?
shpesft
Did the $100 deduction go through on 15 June? If yes, don’t worry about it. It takes quite some time for it to be reflected under Bank and Earn. Mine has been deducted but hasn’t shown up under BnE yet.
Trazora
No step. Bank and earn summary will be updated later in the month.
