DBS changed its Mutiplier plan
F1ngolf2012
i used just $1 to activate the investment category. :s13:
Technically net cost can be $0
Provided the realisable value remains the same as what you pay. :)
oh confused cause like isn't that just referring to net cost can be zero
Let me give a last try. You posted "Technically net cost can be $0" and I responded that "Provided the realisable value remains the same as what you pay."
If realisable value is below or above buy price, would the net cost still be zero? :unsure: Not sure where is the confusion?
X18
Dear all, May I know what would be the interest rate applicable for amount more than $100k? I was not able to find this info from the DBS website FAQ. Thanks in advance.
reddevil0728
0.05% lor. the base rate
NTTDoCoMo
I went on "View Bank & Earn Summary" on DBS IB, it just shows "TermProtect and the Premium". Did not show the "?/12". Am I doing this correct? :unsure:
Able to see x/12 for insurance and RSP using app.
u try tap/ expand your insurance category...hope I recall it correctly :s13:
I always track thru the DBS Mobile App, the Web IB does not show the (N/12).
Select your Multiplier Account > Select Eligible Transactions > Expand "Insurance" or "Investment" to see the Counter.
Buzy_bee
My insurance already reflects 12/12 today. I read advice previously was to cancel when interest comes in October 8th..so should I be buying the a new one today (I read if I buy this month in September it is recognized in October?) or have to wait after October 8th cancelation happens and buy one same day? Thanks!
In same situation as you and I already cancelled mine. May I know why only cancel when interest comes in 8th Oct?
F1ngolf2012
Got it. Thanks.
The x/12 for insurance shows up on DBS digi app but not on IB platform. This is another case whereby DBS "stuffed" up between their IB and mobile app platform. :( The other being FD maturity instruction.
silverbomb
1 share of CFA.SI - NikkoAM-StraitsTrading Asia ex Japan REIT ETF.
via Vickers? under unit trust, somehow it only allows me to invest on 15th monthly not 1 time purchase.
are you treasures relationship holder if that makes sense $0 fee, as $10/25 commission for Vickers unless you're treasures.
MoDiE
this month pang kang liao... :grin:
1l92041H
since mid of yesterday, I am required to use physical token to perform txns.
any of u experience same issue?
never had to use my physical token for so long
