DBS changed its Mutiplier plan
maumu
hi experts, is protectfirst still the cheapest way to unlock insurance?
not expert but.. I decided that buying savings endowment (with lowest quantum) to qualify for the insuance is better than buying the cheapest insurance. at least I'm getting 3.xx% return after one year so I'm not 'losing money' to the bank to earn the bonus interest.
reddevil0728
But this does not take into account the opportunity cost of having to put in a much higher amount and the longer tenure which depending on one’s judgement, may not be as attractive or just similar to losing some money to the bank.
so depends on the sch of thought
60Remajust
I tried to find. But only savvy16 and it’s 3 years. No longer have 1 year?
sglandscape
My view is this is slightly better now since rates are coming off. But end of the day depends on individual.
reddevil0728
I get where you coming from cause you are also locking in rates.
But also depends on circumstances also.
like sometimes we wonder why the lower income don’t buy the item that has a lower unit cost as it will help them save more.
but is cause they don’t have sufficient to buy in bulk hence have to make do with higher unit cost.
so apply the same in this situation.
depends on circumstances lor
maumu
think the latest is 3 years.
actually 3 years at 3.xx% is not bad considering rates across the board are dropping. if the timing was right I would have gotten this before the previous 15 because I needed to clock the insurance category...
furthermore, it's principal + interest guaranteed. nothing to lose.
if worry about opportunity cost, then just put the minimum amount to qualify.
GrandJedi
Will the setup of RSP of $100/mth using my SRS for am ETF qualify as "Investment" category for DBS multiplier account?
spikeling
How long does it takes for a new RSP Invest Saver deducted on 15 Aug to be recognised?
Today is already 17 Aug but my Invest tracker still haven't reflect the amount.
spikeling
3 to 4 working days, depending on fund house.
Ok, I am afraid my Nikko fund is not recognised as I cancelled/redeemed 6 months ago and restart RSP this month (7th month) again.
Anyone got their Nikko RSP deducted on 15 Aug and already saw it reflected in their Invest tracker? Kindly gives a headsup. Thank you!
reddevil0728
u got see the faq? such information can be found in FAQ
https://www.dbs.com.sg/personal/dep... DBS Invest-Saver. How will it be recognised?
see above. always see faq n their website first
spikeling
reddevil0728
I am asking for ACTUAL experience.
You don't have to reply if you do not have any ACTUAL to share.
actual experience does not deviate from the FAQ
since you do not have actual experience. i am telling you the FAQ is actual
n in your first post, you didn't mention "ACTUAL". you only just did
but regardless whether you did or not, the question is have you even looked at the FAQ?
If you have and you still want to ask for validation from others with actual experience whether it is indeed true, that's very fair.
but if you didn't even look at the FAQ, then maybe you should going forward? for anything do some homework first would actually be good.
sohguanh
There is an Ignore feature in this forum if after sometime some particular reader sort of step on your toes every time. Then when free need entertainment you can tap to reveal their posts. Ignore is a very good feature in this forum. Not enough promotion it seems in this forum so I help promote.
60Remajust
yiron
Not yet for me. Usually it's reflected latest by 23rd of the month.
royalmix
Mine (different UT) still not reflected, just wait till next week ( I'am not kancheong cos this is not the first).
Per FAQ, if you terminate/redeemed 6 mths ago, you have to wait exactly 6mth later before it will be recognised, see eg below:
So if you redeemed/terminated before the 15th, should be ok, otherwise, keep your figures crossed? Standby to activate alternative solution to activate the category if it "fails" asap!
Can I terminate my existing DBS Invest-Saver and re-purchase so they will be recognised?
No. For the re-purchase to be recognised, the fund has to be terminated and fully redeemed for at least 6 months from the date of termination or date of full redemption, whichever is later. Alternatively, you may consider purchasing a new fund to continue recognition.
Example:
Termination Date29 April
Full Redemption Date30 April
Re-purchase Set Up DateRe-purchase after 30 October will be recognised
reddevil0728
U shouldn’t restrict your answer to just the dbs link. If u gave him Google.com maybe he doesn’t even need to be in this forum anymore he can find all the answers himself. :ROFLMAO:
Well technically true.
But sadly need to spoonfeed more here
waterpighead
Hi all,
I wanna unlock the ‘insurance’ category hence thinking of buying savvy16 using my SRS. But Ended my SRS account not with DBS. Doable?
I asked the RM and she told me can wor.
