DBS Multi-currency
dreant
Can someone please explain what does USD local and non-clearing means?
I have a USD check sent by mail/letter from US , and i am wondering what are the charges charged by DBS bank.
Thanks soooo much in advance !
Local clearing means it's a USD cheque from a local bank.
Non-local clearing means it's a USD cheque from a foreign bank.
For non-local clearing, it takes about 3-4 weeks. In addition to the 0.125% fee you posted, there will also be agent charges, postage, commissions, and possibly other fees that add up. In the past when I had to do it, typically, they would take out around $25-40 or so per cheque.
If possible, have the sender send you a telegraphic transfer instead. The charges are almost similar, and you usually get the funds within 2-3 days.
I've *heard* that Citibank will clear USD cheques from a US bank with the least amount of fees, if you have an account with them; but I've never used it.
bumdssa
hi guys, sorry for bumping up the thread. can i confirm that i i want to buy say, USD, i look at the Selling TT/OD column?
omelet
Anyone withdrew money oversea with this account? Will I be able to choose which currency I want to withdraw?
stiwipl
You won't be able. SGD is default currency account for debit card payments. That would be sweet though...
stiwipl
yup u r right..but u are able to trsf fx currencies to someone who holds the same acct
No idea. I know that in SCB online fx internal transfers were not possible, only over the counter. Not sure why the limitation, because there was no such for corporate SCB fx -> personal SCB fx. I did not have the opportunity to try DBS fx internal transfer.
expert128sg
this is DBS thread mah. Cfm can dun have to try haha
between diff ppl with diff acct also can
stiwipl
Doesn't matter. Some SG banks carry the same nonsense policy, like for example: try to make fx TT online transfer between SG banks from DBS, UOB, OCBC. Impossible. You have to physically go to the branch for this purpose.
omelet
Well, that's too bad then...
Thought would be able to deposit foreign currency and then withdraw from oversea's ATM...:(
stiwipl
Yes, that would be sweet no? I think HSBC & Citi only provides such flexibility.
foozgarden
not 100% true.
i tried to tx online, as both me and recipient has dbs usd acct.
but i couldnt.
have to go to branch and do it then can.
i dont know why.
lingua101
USD in the DBS Multi-Currency account?
DBS MCA currencies and interest rates
US Dollar (USD)
0.030% First USD10,000
0.030% Next USD90,000
0.030% Next USD250,000
0.050% Next USD650,000
0.100% Remaining balance >USD1m
But I was told they calculate the interest daily and will do round down daily also. Hence if your daily interest is not 1 cents (or 0.5 cents?), you won't get interest at all.
Can someone confirm this?
jiaklormee
Anyone knows if I can do an outward USD TT transfer to a US bank account through the DBS ibanking portal?
Moving to USA soon, thinking of depositing USD into the multi-currency account, open a bank account in USA, then (from USA) initiate a USD TT transfer from my DBS multi-currency account to my US bank account.
In such a case, there will not be any exchange rate charges and the only fees will only be the DBS outward TT fee and the fee levied by the US bank for receiving the USD right?
dreant
You can't send a USD TT from your USD MCA wallet via internet banking; you have to do it over the counter.
Do you have actual USD currency with you now? If so, you're better off just carrying it with you - but do also be aware of civil forfeiture in the US.
If it's just a couple of thousand dollars, it's fine; but you really don't want to be rolling a suitcase full of cash though customs.
If the bulk of your funds is in SGD instead, I would recommend opening an account with Citibank instead.
CGT transfers between SG and US is free, and you can have your ATM card withdraw directly from your USD balance here too. There is also no withdrawal fees if you use a Citibank ATMs there.
stiwipl
This restriction is for USD to US only or for all USD related transfers regardless of the destination?
foozgarden
what is the difference between the usd fx spread rates of ** and DBS?
the reason why i like DBS is that, they do not charge you for depositing/withdrawing USD OTC.
i believe ** does. hence if you roll in with suitcase of 100 large USD. the charge will be hefty
jiaklormee
Thanks for the info. So DBS MCA is out of the question for me.
I will be paid a lumpsum by my sponsor in SGD (not a small sum) which I need to transfer to my US bank account, which will be opened when I arrive at USA.
I need to figure out a way to transfer the SGD to my US bank account, preferably in one transaction, quickly (need to make various large payments when I arrive in USA eg. house rental), and in a cost effective manner. And because I will be physically there, I will have to do the transfer over the internet.
Read about Citibank's global transfer, the problem is that I read in other threads on the topic that there is a daily limit on the transfer amount for new accounts (abt a few thousand a day?), which means I have to do this over a few days. Plus I believe there is a minimum balance requirement, which is a problem since I do not want to maintain my funds in a SG bank account when I will be living in USA.
Fall back option will be doing bank draft (long clearing time, so I have to wait for it to clear before and I hunt for house) or TT using SGD, but I will have to swallow the exchange rate given by the SG bank (I bank with OCBC and CIMB).
dreant
I believe internet transactions with USD denominated accounts is not well supported. I have a DBS USD current account, and I can't even see the historical transactions on it, only the account balance on internet banking.
For DBS MCA, you can pretty much only transfer funds between MCA wallets online.
Citi's spread is not great; but they make up for it with the other facilities and services. If you're changing a significant amount, your RM can arrange a slightly better rate for you.
The other way would be to operate multiple accounts, and shuffle the funds around - that's usually more work than it's worth however.
Yes, the only advantage MCA has, is the ability to get physical USD into the banking system without fees; but that's not a very useful function, since most people don't exactly have suitcases of USD lying around.
Are you moving to the US for work, or are you migrating?
If you're moving, you will find it's important to still have SG bank accounts with good internet and phone banking facilities.
"Not a small sum" is subjective. If it's less than USD100k, I would consider it a small sum in the scheme of things of moving funds between borders.
I really like Citi, and use it a lot. The second most functional internet banking account I've found is UOB. You can pretty much do any transaction via the internet with these two banks.
One advantage of Citi is, it is possible to send a TT via internet banking, with no upper limit (if sent via internet banking secure message, otherwise their limit is SGD250k. Most other banks varies between SGD50k to SGD200k...). Another advantage is, if you have Citigold in any country, you don't need to maintain any minimum balance in any other country. In other words, if you moved all your cash from SG to US, and qualify for Citigold US; you can maintain your Citigold SG status and bank accounts with just SGD1 in the bank here.
Other ways would be, if you have a trusted person in SG; leave the funds with them and TT it across once you've established an account there. You'll still want to change some USD to carry there to get you settled in.
You probably can't open a bank account there, until you have an apartment too.
jane_neo2004
Hi i have about $200k usd coming back after selling my shares in US. What is the most economical way of transferring it back to spore but still keep it in us$ ?
