Dead battery can still power up?
u0206397
Can an old laptop with dead battery still power up when connected to AC power?
Currently most laptops battery is built-in, and cannot be removed.
Intrinion
Senior Moderator
Senior Moderator
Yep, should be able to power up on AC.
And yes, most laptops have built in batteries instead. A hassle to swap it out but still possible.
Intrinion
Senior Moderator
Senior Moderator
If it's dead, it's best to swap it out if possible.
If you notice any signs of bloating / budging from your laptop's housing stop usage immediately.
This was what happened to my sister's Thinkpad Edge with an internal battery.
hawthorne
yup. still can use without battery. My laptop battery died many years ago. Now permanently pugged in to AC power without the battery in
u0206397
Those with built-in polymer battery cannot remove one will still work if it dies?
I know the old type with removable battery can detach if it dies and causes problems. It's just a sliding button to unlock.
