Debugging - Need Some Help
  • Need someone to talk to?
ken_nuff
Hello Bros,
as above I need some help, I've been getting BSOD for the past 1 month,
its a little random, first it couldn't boot to OS kept BSOD. After 2 weeks of no usage, it could power up again, but ocassionally BSOD as I play CSGO. But after a few restarts I could play the game as per normal. used kombuster for stress test and theres no issue. (+ initially the nvidia driver didn't install properly but rolled back and reinstalled properly)
could it be RAM?
here's my Rig.
Phenom IIx6 Thuban 1055T 2.8GHz
GA-MA785GPM-UD2H
MSI N560GTX-M2D1GD5
PSD22G6672H 2GBx3 DDR2 Patriot
Adata S510 120GB + Seagate 250GB Raid 2+0
BenQ V2410Eco 24" LED-Backlit LCD
Seasonic M12II-520Bronze 80Plus Bronze!
Windows 7 Professional (64 bit)
suavegamer30
yes, most likely it's due to the RAM.
Btw, how old is your RAM? Any RAM replacement before? BRAND?
royfrosty
Hello Bros,
could it be RAM?
here's my Rig.
GA-MA785GPM-UD2H
MSI N560GTX-M2D1GD5
Do a memtest and see how it goes.
peterchan75
Have you reseated your RAM modules ? If not, just try it. Sometimes, it might be RAM module contact issue that cause BSOD.
ken_nuff
my ram is rather old, reused them from my P4 LGA775 rig upgrade.
ok.
ok, will do. Thanks Bros, will keep a notice after rearranging and mem test
bhtan83
No bother testing. For me, that ram should be more than 6 years and I won't waste time doing memtest cos it takes a lot of time. Just use HD tune to check ur OS drive.
Especially if ur ssd fails it will fail completely. Unlike those mechanical hdd, even with slight bad sector u might still be able to boot into OS.
