Dedicated Sound Cards
TakemiAzusa
Does anyone sell them these days since everything is on board ?
if so , recommend me a good card.
I have just recently bought the JBL QUANTUM DUO PC GAMING SPEAKER
On board sound is good , just thinking if I should get a dedicated and if people do sell it these days
Goodshot
Those $12-15 one from Lazada definitely better than onboard. But I rather spend $89-100 buy the Asus sonar Se
TakemiAzusa
randomly searching google and this popped
Sound BlasterX AE-5 Plus /
AE-5 Plus Pure Edition​
any good reviews ?
wwenze
If you connect via USB then buy soundcard also no effect
TakemiAzusa
you assumed I connected a powerful JBL using USB ?
No. its 3.5 to onboard sound card
anyways besides Asus sonar Se , what else ?
Yongkit
Wondering if TS try the USB connection and the JBL software feature?
wwenze
No, I assumed you wouldn't be stupid enough to connect a powerful JBL using 3.5mm when it is using a TAS5760 amplifier with ONLY digital inputs so your analog audio will be converted back to digital first hence ending up with even worse quality than connecting straight via digital to begin with.
https://fccid.io/APIJBLQTMDUO/Internal-Photos/Internal-photos-4581060
TakemiAzusa
? lost , JBL QTDUO using 3.5mm is bad ?
USB better ?
eh ... LOST
care to explain
how come USB in this case is much better than on board 3.5mm
86technie
3.5mm is not bad as the speaker supports USB, USB will be better than 3.5mm since USB is a digital interface
while 3.5mm is analogue cable.
moi entry level use
FiiO K3 Type-C USB DAC Headphone Amp​
Hafi
wtf I went to lookup this JBL model this crap cost $269?
The look and input/output so lame and so 90s. I dunno how it sounds but I dun expect much from it.
TakemiAzusa
**** off troll. I will report your account
kandinsky
Yongkit
Software ? you mean Quantum engine ? downloaded it but it says for Headphones only ... which is the right item ? its on USB now
JBL Quantum Duo Specs & Downloads
upon connected through USB you can now update your USB driver & software upgrade for speaker if you have not done so as screenshot below red circle.
yes you are correct it is not supported by the QuantumENGINE software
nevertheless you can go to the task bar right corner "sound" icon right click to see what are the setting or properties available for your speaker and play around.
Hafi
wtfh4x
Price breakdown:
2.0 Bluetooth speaker hardware - $69
RGB LEDs - $200 :s13:
Such is the state of the PC components market.
hyperfuse
I just gotten the edifier bookshelf studio monitors. Edifier r1280dbs. It looks aesthetically nice with its wood accents. The audio quality is superb as well. Very well balanced and not muddy. Cheap too.
With shopee coupons, its $124. Add some shopee coins and it cost me $116
