jonathan920
- Sep 16, 2008
Anyone has experience in building a desktop for '3D Modeling, rendering, design related' purposes?
Budget : 2k - 2.3k
Any advice related to ''3D Modeling, rendering, design related' rig will be greatly appreciated.
Planning to build one this month, any shop or person to recommend?
Update
Rendering Software : Rhino & Autodesk Revit
Other Softwares : Adobe Products ,Grasshopper(Rhino Plugin)
Autodesk 3DMax Program
Autodesk AutoCAD
Autodesk Maya!!!!
Autodesk Ecotect Analysis
Autodesk Simulation 360 Simulation
I did a read up and realise CPU are used to render , not so much graphic. Will depend on how the budget 2.3k?
Current Plans
128gb SSD
1TB HDD
??? CPU(Mid Range / High End)
??? GPU(Entry Level)
32GB Ram
Wifi adapter
Any Motherboard that can fit items as above
??? PowerBox
DVD Drive
Extra
Monitor(22++ Inch onwards), Speakers, Mouse Keyboard
Cooling Casing(Almost 24 hour running) - No Overclock needed
Budget : 2k - 2.3k
Update
Autodesk AutoCAD
Autodesk Maya!!!!
Current Plans
128gb SSD
1TB HDD
32GB Ram
Wifi adapter
??? PowerBox
DVD Drive
Extra
