Desktop unable to power on
thatsmallboy
Hi, I have a rig that I assembled myself about over a year ago. Powers on and works fine whenever I keep the power socket switched on. Sometimes when I switch off the power socket at night and turn it back on the next morning, I am unable to power on the desktop. I will need to switch off the power socket and come back to try again after awhile. Any idea on what could be the cause? Or any shop I can bring the desktop to for servicing?
tsteo77
Pc care and solution - 1 rochor canal road,sim lim square #02-32 Singapore, Singapore 188504. ( +65 9048 7338, nigelng81@gmail.com ).
H.sHon
I had a fairly similar situation awhile back as well.
When I press the power button, it takes awhile for the power to actually kick in.
But like what the other's mention, it's the PSU issue.
obichacha
Power button failed, can try to jump start with screwdriver or test pen else. YouTube video can find it.
Another is PSU failed.
It's_Not_Me
Did you overclock? May have problem with booting if OC is unstable. Check your ram as well.
thatsmallboy
Just got a replacement unit for the PSU, still getting the same problem. No overclocking done. Could it be the ram/mobo?
My speakers can get power though
Aiya give up la tomorrow go find Nigel
obichacha
Try jump to start, if cannot power on, is the mobo issue
Bring your mobo for warranty lah
wtfh4x
Unplug all your external devices and try again. Sometimes USB devices can cause weird behaviour like this.
