Did i kena speed camera?
teddy_97
Was driving on AYE just now and forgot AYE has a speed camera so was cruising at around 90km/h. As I approached this overhead bridge I realised there was a camera so I stepped on the brakes.
Slowed down to about 85km/h I recalled looking at my speedo before crossing the camera.
After I crossed the camera I looked at my mirror suddenly got a flash. Don’t know if the camera captured me or the cars behind. But at this point I was already about 3-4 cars length ahead already.
Can someone tell me if it was me? Anywhere to check if got kena?
Stallone
90kmh is not even speeding
This is outside nus with 90 limit right
mp4005 help
Suspended
I kana flashed by the speed camera quite a few times over the last few years (SLE towards woodlands past mandai). That speed camera has an issue with the speed. Travel at 80 kmh also sometimes flash.
But so far no letter. So ultimately just wait for the letter .. and hope don't kana. As long as you are not too fast (less than 10kmh) above speed limit, may kana warning only if you have a good track record.
iantao99
If u r 85km and only 3-4 cars length away, cars behind u can’t b speeding as well.
It’s probably flashing at cars on other lanes.
Did any cars overtake u at the point?
spoon
This camera easily flashing at cars I always very careful when I ride pass. Flash should be very “instant” most likely not u.
georgemcics
Aye this speed camera will dummy flash one
I go 80 kana flash before also
But no record no nothing
Another one is the sle toward city
Suka suka 80 also flash one
Sent from LOL VICTOR LYE THIAM FATT using GAGT
jumpmanz
That cam something wrong. Few months ago also kept flashing non-stop
Sent from Molten GG7X Basketball using GAGT
zzt231
Don't boliao lah.
Those camera got margin of +-10km/h
Usually I go pass it at higher speed unless got idiot blocking .
Nv kana before in 20 years of driving .
Posted from PCWX using never on bended knees
Darwinson
Wow the camera pointing which direction ah ?
I thought the camera capturing passing cars towards jurong
But the other camera seem to
Flash. Was driving 94
Conan1986
there are two cameras, one for each direction. static camera always captures the back of your vehicle so meaning you pass already they detect speeding then it'll flash.
good luck
andyhtc
Suspended
Most likely another car. Next time give yourself at least 5 km/h buffer when passing these speed cameras.
ceecookie
This stretch is 90 so you are ok. Even if ur speedo is 90, actual speed is around minus 5km/h so won't trigger.
For static speed cam, effective range is only 100m or 2 seconds after passing at speed limit. Once u passed this distance, camera is out of range. :)
Darwinson
good luck
If capture back of car then I have chance. Cos I saw the ‘towards city’ camera flashing while I was driving towards jurong. I was within 100 m. I always assumed camera capture back of car so I was cruising 94 to slow down adjacent to camera
Checked onemotoring for offense. So far nothing
Conan1986
actually 94km/h shouldn't trigger the speed camera, it does have a bit of offset, usually around 10%, some times the flash can go off without any cars speeding as well. don't worry too much, if kena, just pay and drive safe, if never kena, also take it as a lesson and drive safe :s13:
