die liao, need help~
GhostWhere29
computer rabak alr.
ytd working fine.
i first turn on, without display but can boot ( heard window sound)
2nd try reseat ram. got beeep beep beep non stop. follow by auto restart.
3rd try take out gpu. use onboard graphic. (DVI cannot work) (VGA can work)
anyone know what problem is it, so i can narrow down my troubleshooting. or should i say anyone understand my grandmother story .:s13::s13::s13:
appreciate if anyone can help . spec >>>
peterchan75
Let's eliminate two variable first i.e. the GPU and hard disk. Of course, high chance it's not the hard disk but disconnect the power to the hard disk anyway. Remove the GPU. Connect monitor to your motherboard onboard video out. Boot with 1 RAM module.
1. If still beep... reseat the ram module. If boot to BIOS, insert 2nd module.
2. If reseat, still beep, remove this module, and boot with other ram module.
Hopefully, you can find out if your ram module is faulty. If the ram modules boot fine, then work on your GPU. Connect your monitor to your GPU.
GhostWhere29
99% GPU gone up lorry .......
guys now its working, i tried on my 2nd pcie slots and its working. can i assume its motherboard that need to be rma?? how is rma for gigabyte???
GhostWhere29
-_- now bsod . Went gigabyte rma . They say no problem with board. Now i go hone kena bsod cannot even boot up .
babycis
You must try this 2 simple step.
1) take out rams from mb, clean and put back mb.
2) take out gpu from mb, clean and put back mb.
muddle
Try single ram and swap the slots till can boot. If still cannot, take another ram and go thru all the slots again.
GhostWhere29
I have tried. But in vain . I reformated and it work . Currently gpu spoilt as well .is there a possible spoilt gpu causes hdd to fail as well?
Blehana
Bro, if the mobo is not spoilt then could well be your graphics card. You could bring down your PC to gs (Nigel) at SLS, he can help you.
