Digital Lock 100% Safe boh???
swenson
Digital lock user for the past 3-4 years.
So far the convenience is the best pros
The model I have, only card, keypad and fingerprint. I choose NOT to have wifi, and face options
When numeric/fingerprint input fails 5 times, the whole system will be inactive for 30min. can only be opened from inside remote, other input method all inactive.
The bolt is also thick and internal, can only cut with power saw, provided the blade can fit between the gate joints, but then again, with such tool, can just cut the metal gate and the noise is a dead giveaway, unlike conventional locks, can use a clamp cutter
Every system have pros and cons, weakness and strength
ksapple
dunno i use my yale since 9 years back liao
No issue, i bought from USA, is connected by zwave for online monitor and notification
plus i have ring doorbell
is basically a deadbolt with keypad,
if u tink deadbolt is secure jiu secure lor if not then not secure, i dun really lock my metal gate
d3n
i used Yale brand digital lock (pin and card only) for 8 years and now currently using Solity brand digital lock (fingerprinter, card and pin) at my current place for 1 year plus.
totally no issues. never got lock out of my own place before.
