This is asking too much. Water cooling also hard to get 40deg at.load with ambient at 31deg. Lol
If no air con, then use PC will sweat like machiam eat steamboat.![]()
Can. Saw someone using 3x360 rad before, and he was complaining his full load temps of 30-40 was too low![]()
Too low or too high?![]()
What parts is your system comprised of and how are you placing it? Even my Powercolor 7870 myst running naked without case about 70cm to my left I dont even feel anything when playing games like Grid 2 or COD ghost.
hello? time to wake up? even custom water cooling cant hit 40C in sg...
I thought if the graphics card is constantly running at 50 to 70 celsius, and passing out the heat, sooner or later the room temperature will rise to probably 35 to 40 celsius because of the hot air?
Will at least be hotter than under the sun in the open? No?![]()
You seem to be saying a statement more than asking a question though, like you already believe a discrete graphic card will turn your room into a sauna room. Oh well your loss not oursOK then. Guess I shall stick with IGP (Intel HD Graphics and AMD APU). Shall not bother with the idea of discrete graphics anymore.
Thanks all for sharing your knowledge.
And I forgot to answer the most important question, or misconception in your original post. Intel IGP or even AMD's relatively much stronger APU are very tiny compared to the die size of even entry level models like AMD HD 7750. Bigger die = much better performance but of course also = more heat. But definitely nothing close to "standing under the sun". Have you actually tried standing under hot sun? I dont think any graphic card can come close to that kind of heat.Is it ever possible to have a discrete graphics card running below 40 degree Celsius at load similar to IGP, assuming room temperature is about 30 or 31 degree Celsius?
You are very very misinformed lol. Unless you're playing in a room the size of a bed with no ventilation, the graphic card wont be able to heat your room to such temperatures. If not sauna rooms will be using graphic cards instead already![]()
