artyboy
- Jul 7, 2002
Played on the 2nd card for an hour + at max temps of 65C on CPU and GPU at 76C w/o any crashes. So it seems that the cards are fine. I only played COD-BO2 for this test as no point playing Crysis 3 as its known to always crash even before i upgraded my comp (i.e. using previous CPU/GPU/RAM. I did this test using the top PCI-E slot. Seems like the crash only occurs (with all games rather than just Crysis 3) when im playing games in SLI mode. I find it puzzling since my 1,200 watts PSU should be up to the task of powering 2 cards(?). Heat dont seem to be an issue, unless 75C is too close to Nvidia card's 79C (80C) temperature target? I don't know how that works out. Is there any "Dual GPU" which i have to enable on the mobo or something?
Btw the temperature difference of CPU:58/GPU:67C and CPU:65/GPU:76C between the 2 tests is because the first test was done with the PC case's side panel open for the first test and closed on the second test (not deliberate, i just forgot).
), off the monitor and speakers and left it to run overnite. When i wokeup this morning, the game didnt crash. I don't know if that is the same as "playing the game" for (more than) an hour
