Hi,
I am looking to build a gaming PC with options to future proof. My budget is set at $1500 (able to go over if really needed)
Games that I would like to play at 120fps(or higher) would be:
1) PUBG
2) Fortnite
3) Dead by Daylight
4) CSGO
5) Fallout 4
6) GTA 5
- And other future releases that are graphic intensive.
Also, I would like to livestream the games that I play. So the build has to be able to livestream and game at 120fps smoothly.
Some other functions that I need would be:
a) Able to have bluebooth. As I would like to connect to my JBL bluetooth speaker.
b) A chassis that is able to have its panels removed so that it is easy to remove any dust. My current 'Headway X810 Black Mid Tower' chassis' front panel cannot be removed. So when I need to remove the dust from the front part of the chassis, I am not able to do so.
c) I would like to have 12gb of RAM or more (Not sure if 12gb is possible. See questions below)
d) Dual monitors would be nice. To be able to game on one monitor and watch a livestream(video) on the other. Currently I have a 'Viewsonic 22" LED VX2270SMH' monitor. And the refresh rate is 60hz if I remember correctly. So that will definitely be the secondary monitor as I would like to game at 120fps. The primary monitor should be 120hz? Or is there an even higher refresh rate for a monitor?
Some questions that I have are:
1) Is it possible to get 12gb in a rig? Or is it only 8gb then a jump to 16gb?
2) In my current rig, with a 'Headway X810 Black Mid Tower' chassis, about half of the time when I turn my PC on, there is this very noisy and loud fan spinning. I'm not sure if it's the chassis fan or one of the other hardware. Could someone advise me on this?
3) Currently I have a 'Western Digital Blue 1TB'. I bought it in January 2014 and have been using it since. Is it possible to bring it over to be used in the new rig? Or better to just buy a new HDD? (And how much space does an average gamer need for his HDD? Is 2TB enough?)
Lastly, this is my current rig that I built in January 2014. Not sure if I can bring anything over to the new build.
CPU: Intel® Core™ i3-3220 Processor (3M Cache, 3.30 GHz)
Motherboard: ASRock B75M-DGS
RAM: ADATA Premier DDR3-1600 CL11 4GB.
GPU: PowerColor HD7770 GHz Edition 1GB GDDR5.
Chassis: Headway X810 Black Mid Tower
PSU: Corsair CX500M 80 Plus Bronze.
HDD: Western Digital Blue 1TB.
ODD: Samsung 24X CD/DVD Writer [OEM].
OS: Microsoft Windows 7 Home Premium 64-bit [OEM].
Monitor: Viewsonic 22" Full HD LED VX2270SMH
Thanks in advance.
1) PUBG
2) Fortnite
3) Dead by Daylight
4) CSGO
5) Fallout 4
6) GTA 5
Thanks in advance.
