hi, helping a friend out. i can fix up a pc but i know nothing much about the spec this days. so need some advice from all the guru out here.
Budget about 1k. can be more but not too much.
he looking to use the comp to surf net, movie and play dota 2, company of hero 2, rome 2 this type of game ( setting unsure high sure be good i think). dont think he wan or need to OC his system
he have a 1080p 32'' tv may upgrade to a projector. only request he have is to use Nxzt s340 case or something similar. he should have a OS.
Not in a hurry to build so shell he wait for the the next pc show or some new gpu to be out before he build this pc.
Every advice helps. thanks.
