3.1 is usually done with 4 channels using 3 normal speakers and one subwoofer
Your implementation won't work because the 2.1 sound bar won't know it is connected to center/sub, it will assume it is connected to L/R and behave accordingly. So the left driver will produce center, the right driver will produce sub, and the sub will produce sub.
One more thing: You need your front speaker to sound the same unless you enjoy your protagonist changing voice as he moves across the room.
3.1 is 2.1 with front speakers.
so connect the soundbar to l/r and the other to front. then choose 3.1 in settings
Yah, that's what I am hoping to achieve.
Except in windows, there's no 3.1 config. I would have to select 5.1 but disable the rear channels.
