[DIY] Advice on building dekstop?
smelly snail
Hi all, am new to this so hoping to get advice and recommendations. Mainly for gaming, watching movies etc.
Budget will be around ~1.5 - 1.7k I think
The parts I've roughly chosen after looking @ the price lists and googling for reviews are as follows :
Gigabyte GA z97x Gaming 7 + i7 4770
Crucial PC-3 1600 DDR3 (8GB)
MX100 256GB
Western Digital 2TB Purple AV
MSI GTX770 Twin Frozr 2GB Gaming
ASUS 24X DVDRW SATA
Super Flower Leadex Gold 750W
Cooler Master X6
Not sure if its sufficient / overkill or if anything is missing...
Please advise, thanks in advance! :)
PS: When does SLS re-open?
mib500
MX100 256GB
ASUS 24X DVDRW SATA
Cooler Master X6
Should get GTX 970 better.... within your budget....
Jian19
i5-4460 + Msi h97m g43 ~ $404
G.skill Ripjaws 8gb ddr3 ~ $125
Crucial mx100 256gb ssd ~ $159
Wd red 2tb ~ $131
Msi gtx970 armor edition ~ $499
Superflower leadex 650w ~ $139
Samsung oem drive ~ $25
Fractal design R5 ~ $139
Win7 64 oem ~ $130
$1750 buy and assemble @ pctheme ask for discount.
royfrosty
MSI H97M G43 + i5-4460 ~ $363
GSKills Ripjaws 1600mhz 2x4gb kit ~ $115
WD 2tb Purple AV ~ $124
Crucial mx100 256gb ~ $152
MSI GTX970 4gb Armor Edition OC ~ $485
Seasonic S12II 520W 80+ Bronze ~ $84
Corsair Obsidian 450D ~ $159
LG DVD Drive ~ $21
Windows 7 Home Premium 64bit OEM ~ $115
Total ~ $1618. Buy at tradepac, DIY
smelly snail
thanks for replies.
two qn : do i need some sort of wifi stick?
& on the tradepac price lists for graphic cards, there's A and B. (B being more expensive)
what's the diff?
halnala
thanks for replies.
what's the diff?
Wifi stick is for connect wirelessly, add on if needed. The prices are bundle and non-bundle prices.
monikernemo
thanks for replies.
what's the diff?
I think they quote A for you if you buy a lot from them (just try to cut prices either way after making sound calculation)
smelly snail
Thanks ; will need the wifi stick definitely because modem is 2 floors up.
Is it more advisable to buy from TP or PCT? Will be bringing thick skinned bargain hunter friends for the record haha.
Should be able to get discounts right? Looking at the recommendations, if include monitor etc I think can reach 2k already :spin:
