X66
- Jan 1, 2000
I am glad that there are people who find my article useful. To answer some of the question...
Interesting! Can write a guide with picture and share with us how you did it?
Will PM you. Cheers
Fortunately, I have not once spill any used engine oil with this extractor. I have been deposing the used engine oil in the big drum for used engine oil at the car workshops.
I tried mobile 1, shell helix and the engine oil turn super black after 5,000km. Maybe it's my car. Hence I decided to change ever 5000km instead. I do not wish to have super black engine oil to stay in my engine for more than 5,000km.
YES!!! This is what exactly what I do. Change engine oil myself at 5,000km. Bring to workshop for proper servicing at 10,000 km (and hence change the oil filter) At the 15,000km change engine oil myself again to make sure the black engine oil dun stay in the engine for more than 5km. Hope this answer the question on engine oil filter =)
So what I did is invest in this:
FUMOTO ENGINEERING
Been using this for ages. So I don't need to remove the bolt and risk stripping the threads. Only sucky part is that its very expensive (cost me USD25).
thanks for sharing.
Can you PM me where to get the extractor?
Will PM you. Cheers
Good write-up by TS on oil changing but would be ideal if TS were to provide environmental awareness such as using drip tray for such DIY in case of accidental spills and such.
TS, assuming you buy turtle oil at 29.90, changes every 5km, that means every 10k u will spend about 60 on oil...
why not try oil like mobil 1? definitely can last 10k and cost less than 60 for 4 quartz...
Change at 10k.
This is meant for those who wish for an oil change in between the AD's interval.
Some oil filters are located on the top of the engine, so you can DIY the replacement.
