DIY CPU PRO please help
Neal Caffrey
Eh, completely noob in this and wanna try making one mini cpu myself
Just trying to build a CPU to stream video with foreign application and youtube without lag.
Anything wrong or i should change? Thanks!
NEW LIST
-[CASE] Thermaltake Core V1 Mini ITX Cube Computer Case CA-1B8-00S1WN-00 ----$58.40
-[Processor] Intel Skylake Core i5-6600K ----- $271
-[MOBO] ASUS z170i-pro gaming m-itx ----$285
-[Cooler] Cooler Master Hyper T4 CPU Cooler w 4 Direct Contact Heatpipes RR-T4-18PK-R1 ----$29
-[RAMS] Crucial Ballistix Elite 16GB Kit (8GBx2) DDR4 2666 Unbuffered DIMM - BLE2K8G4D26AFEA / BLE2C8G4D26AFEA -------- $150
-[PSU] Thermaltake TOUGHPOWER 750W 80 PLUS GOLD Full Modular Power Supply PS-TPD-0750MPCGUS-1 ----$106
-[SSD] Transcend 256GB MLC SATA III 6Gb/s 2.5" Solid State Drive 370 ----$98
-[SSHD] Seagate 2TB Desktop Gaming SSHD SATA 6Gb/s 64MB Cache 3.5-Inch Internal Bare Drive (ST2000DX001)--$117
-[CASE FAN] 2x ARCTIC F8 PRO PWM PST ----$8.75 each
-[PASTE] Arctic MX-4 ---$12
Total: $1135.40 before Window OS and Graphic card *maybe not*
-[CASE] Thermaltake Core V1 Mini ITX Cube Gaming Computer Case CA-1B8-00S1WN-00 ----$58.40
-[Processor] AMD A10 7870K Processors 3.9GHz Socket FM2+ 95W ----$152
-[MOBO] ASRock FM2A88X-ITX+ FM2+ ----$184
-[Cooler] Cooler Master Hyper T4 CPU Cooler with 4 Direct Contact Heatpipes RR-T4-18PK-R1 ----$29
-[RAMS] Corsair Vengeance Pro 16GB 2x8GB DDR3 2400MHz, Red ----$128.50
-[SSD] Transcend 256GB MLC SATA III 6Gb/s 2.5" Solid State Drive 370 (TS256GSSD370S) ----$98
-[PASTE] IC Essential E1 ---$12 or Arctic Silver 5 ---$15
Total : $902.40 before Window OS
Koenig168
For video streaming, just about any setup will do so long as you have Gigabit LAN, HDMI and decent wireless.
You might want to add in a GPU (for gaming) and HDD.
Koenig168
You might want to consider an Intel setup instead of AMD as the latter tends to run hotter.
Neal Caffrey
Thanks!
well the AMD A10 only around SGD150 lor.
and GPU too ex leh >.<
and i worry the rams might not works as it's only tested on intel but by right, should works leh LOL.
Koenig168
One more thing, the casing is mini-ITX which is a very small form factor. The motherboard is ATX which is way too big for the case.
DawnsTear
[Mobo] H110M-ITX/D3 /w i3-6100 $296.00
[RAM] Kingston DDR4 2133Mhz CL15 (8GB*1) - $67.15** (Lazada)
[SSD] Samsung 850 Evo 250GB - $122.08'' (Lazada)
[PSU] FSP Aurum S 500W Gold 80+ - $84.15** (Lazada)
[Case] Thermaltake Core V1 - $79.00
[OS] Windows 7/8 Professional 64bit OEM - $29.00 (Reddit)
Total :- $706.38
Buy from PC Themes unless stated otherwise
** Buy from Lazada SG App
MasterCard Monday (15% off capped @ $25)
CitiBank Wild Weekend (15% off capped @ $25)
" Buy from Shopback -> Lazada SG
Lazada Shopback 5% off
Note* - Take 60 days to get the 5% back
Neal Caffrey
Thanks ah! but actually i already ordered everything :s22:
Total :- $706.38
djdestiny
I don't think so. Firstly if he's going haswell (it's cheaper) haswell is actually known to be hotter.
I have a 7850k that ran 55C tops on the stock heatsink. ;)
Compare that with 70-80C on stock heatsink from a i5-4460 on the copper core heatsink :D
lol, i can always sell away certain part, but not changing whole set.
I would say with modern games (especially the new ones) you will appreciate extra cores. Even if the two extra cores are a bit down on power.
If you already have it then ok. If you don't have you can go for a i3-6100 + H110 mobo (You'll have to be exact with the ram on the other hand)
or G3258 + H81 ITX mobo and overclock the CPU a bit.
Or a Athlon X4 860K if you can find, those are better for dGPU usage. A 7870k by itself is quite lame for actual gaming.
Lastly if you have already bought the parts don't ask around here. Confirm plus chop kena flame.
Total :- $706.38
Bodoh! you specified a DDR4 part for a DDR3 motherboard. WTF?
Secondly Skylake must use DDR3L.
Secondly the iGPU must use dual channel or else it will suffer 20-30% penalty. That is for DDR4-2133.
Neal Caffrey
Just bought a Asus z170i-pro gaming m-itx FOR $285. which processor should i pair with? Thanks
Neal Caffrey
It is inly compatible with a skylake processor
ya i know but which is the so called "most value"? i3 which? or i5 which? Thanks
Intel Skylake Core i5-6600K ----- $321
Intel Skylake Core i3-6300 ----- $200
Intel Skylake Core i3-6100 ------ $159
or any recommendation please.
DawnsTear
Copy wrong from my google doc xD
Any link to show the 20-30% penalty.
Get i5-6600K ? Since u alr got Asus Z170i Pro Gaming
Neal Caffrey
New items list, anything wrong/should change or i bought overpriced?
-[SSD] SanDisk Internal SSD 240GB 2.5-Inch SDSSDA-240G-G25 ----$90
------------------------------------------------------------------------------------------------------------Total: $1135.40 before Window OS and Graphic card *maybe not*
zenniz
The CM Hyper T4 cannot fit into the Core V1.
The power supply is overkill too. Your computer's power consumption will be very inefficiently.
since you so rich, i don't think you will care.
Neal Caffrey
Hiii, no idea where u get the part of me being "rich"
anyway as mentioned, im totally noob in this and here i am trying to learn from you guys.
Eh i think CM hyper T4 should fit as according to other online build guide for Core V1.
and hmm.....how much PSU should i buy instead? Thanks!
fhkyhnpm
Sorry TS, borrow your thread.
Have a noob question, going to pick up a Asus B150-Pro gaming MOBO, can I use back Kingston DDR3 1600 4Gx2 which I was using on my z77 mobo? Or I need to buy new ddr3L ram? Pls enlighten, thanks.
