siaokia2806
- Aug 23, 2010
A total computer noob here. Would be glad that if someone can help me out. Just need a normal setup that enable me to play dota 2 at max setting. Thanks in advance.
1) Budget?
2) Monitor, KB&M ?
Half-decent budget gaming rig
CPU+ Mobo: ASROCK H81M-HDS + G3240 (156)
RAM: G.SKILL PC 12800/1600MHZ DDR3 CL11 VALUE RAM (4GB) (50)
GPU: ZOTAC GTX 660 SYNERGY EDITION (189) (lazada.com)
SSD: PLEXTOR M6S 128GB (99)
HDD: TOSHIBA 1TB 7200RPM (69)
DVD-RW: LG 24X DVD-RW SATA OEM (25)
PSU: THERMALTAKE SMART SE 530W (75)
Case: CM K282 / K350 / K380 (55)
OS: WINDOWS 7 HOME PREM (120)
Total cost: $838
Ultra cheap, barebones basic gaming rig
CPU+ Mobo:MSI FM2 A75MA-E35 + A6-6400K (198)
RAM: 2X KINGSTON PC 10600/1333MHZ DDR3 CL9 VALUE RAM (2GB) (80)
PSU: FSP 300W 80% ATX PSU (39)
Case: HEADWAY ATX CASING (30)
Total cost: $561
Unless otherwise stated, buy at PC Themes, #04-15, and ask for discounts. DIY yourself. If you can't into DIY, get PC Themes to assemble for you for a fee.
Notes:
1) Not sure how cheap do you want to go, but both rigs are capable of playing DOTA 2 at max settings. Pick one.
Erm.... I neither own a shop, nor am I selling anything.Do you have stock for the zotac gtx 660? Or must I order online and bring it down to your shop?![]()
Ops. Hahaha sorry. Thought you were the shop owner or something. Anyway I went to download pc themes brochure and come up with a setup. Can you help me see again whether is it value for its price or should I stick to the half decent budget setup that you recommended? Thank you once again
CPU+Mobo: Asus b85 pro gamer with i3 4160(325)
GPU: Zotac gtx 750 ti 2gb ddr5 (219)
PSU: Super flower leadex 650w gold fm (139)
Casing: Cm k282/ K350 / K380 (50)
RAM: G.SKILL PC 12800/1600MHZ DDR3 CL11 VALUE RAM (4GB) X2 (100)
DVD-RW: LG DVD-RW SATA OEM (25) 24X
Total cost $1146
Ops. Hahaha sorry. Thought you were the shop owner or something. Anyway I went to download pc themes brochure and come up with a setup. Can you help me see again whether is it value for its price or is there tweaks to done or should I stick to the half decent budget setup that you recommended? Thank you once again
Total cost $1146
How sure are you that HD 8470D can max out Dota 2? What screen resolution are you referring to here?Half-decent budget gaming rig
Total cost: $838
Total cost: $561
Notes:
when buying these items, i know these shops will fit the cpu to mobo if requested. How about the cpu cooler?
I am very sure that the HD 8470D is capable of maxing out DOTA 2 at 1920X1080 resolutions. Check out these GPU benchmarks of DOTA 2:How sure are you that HD 8470D can max out Dota 2? What screen resolution are you referring to here?
Erm... if you wanted something more powerful, you are kinda doing it wrong. You spent too much of your limited $$$ on a mobo that does not actually help contribute to overall system performance, and the GTX 750Ti is actually a downgrade. (Don't look at the GTX 660 like machiam old old cheap cheap one, the GTX 660 is actually faster than the GTX 750Ti.)Ops. Hahaha sorry. Thought you were the shop owner or something. Anyway I went to download pc themes brochure and come up with a setup. Can you help me see again whether is it value for its price or is there tweaks to done or should I stick to the half decent budget setup that you recommended? Thank you once again
Total cost $1146
Free-to-Play Games Benchmarked: 4 Popular Titles Put to the Test > Dota 2 Benchmarks - TechSpot
Results: High Details, 1920x1080 - Dota 2 Performance, Benchmarked
Granted that you are going to get about steady 30FPS during DOTA 2, but DOTA 2 is more of an isometric view strategic game than a FPS, 30FPS should be playable for DOTA 2. Of course, if you think that multiple characters using their skills or being bombarded by various AOE spells is not going to do wonders to the framerates, please sound off.
Budget between 600-800 want to keep it as low as possible if can. Max can stretch 1k.
Only need cpu, don't need monitor or kb and mouse.
Thanks![]()
You can double the number of real physical CPU cores and SSD NAND capacity, and upgrade GPU and PSU to next higher tier at nearly no additional cost.Ops. Hahaha sorry. Thought you were the shop owner or something. Anyway I went to download pc themes brochure and come up with a setup. Can you help me see again whether is it value for its price or is there tweaks to done or should I stick to the half decent budget setup that you recommended? Thank you once again
Total cost $1146
