guyferic
- Sep 5, 2005
Gigabyte is fine for your mobo. But why not 850 Evo instead of Pro for OS drive?
Also, I think buying RAM from Amazon is cheaper, cheapest 2x8GB is ~80SGD, but only if you can wait, and buying other things to make up for the 125USD free shipping, then nvm, buy from sls.
Lazada has 12% off on DBS/POSB Fridays if you have their cards and you use their mobile app.![]()
Just a feeling that the Pro is much better than Evo although reviews says it doesn't make much difference
I will most probably take the Avexir DDR4 2400Mhz 16GB(2x8gb) from Corbell(Lazada). The casing will be buying from them as well.
And I'm changing the CPU cooler to the $39-Cryorig M9i
