DIY PC Parts recommendation
soulz81
Hi all,
I intending to build a new pc ...last diy pic is like 5 years ago.
I am not really familiar with the latest and latest right now ...and what brand of parts to go ...
Can offer me some help?
I want to build a pc for photo editing (raw file is 50 Mb) and video editing (4K). My budget is 2k if possible.
I don't do much video editing so if rendering is slower a it to fit into the budget ...it is fine with me as well.
I do some light gaming.
Of the top of my mind
CPU : i5 or i7 ? Sky lake or kraby lake
MB : any recommendation ? Is m.2 port a must nowadays?
Ram : 16 gb or shld I go 32 gb ? Fastest is ddr4 right
Video card : 1070 ? Or do I need higher ? What models good?
Hdd: ssd + hdd .. again which brand is good (fast read write and reliable )
Many thanks in advance ... I will do some read up in the mean time.
soulz81
Do you do overclocking?
Is aesthetic important? Any build theme?
Need wifi?
Pc on desk or floor?
How much space allocated for the pc? (to determine which kind of tower you would be getting)
Sent from Overpowered Phone Mark III using GAGT
Thanks in advance.
I would prefer ITX casing but my experience is small means additional premium .. Harder to get mobo with 4 ram slots or two video card slot etc not to mention heat can be an issue.. Harder to find small size graphic card as well.
I am fine with standard Atx case. I would put it on the floor. I usually get those lian li case .. Looks as long as not ugly can liao. Ventilation to me is more impt haha.
As for WiFi .. If mobo has WiFi then ok. If no WiFi on mobo then I will just grab a net work card
singupingu
For itx it's not really that bad these days. Fractal design node 202 is one of the best itx now imo. The components are segregated, gpu compartment can house most of the 2 slots full sized cards, can add 2 more fans to cool it down as well while maintaining positive air pressure on the chassis.
The limitations are the ability to overclock as thermal dissipation definitely not as good as full towers. It's also more expensive to get sfx stuff and the limitation of 2 ram slots only but a 2x16gb can go a long way.
Anyway, you haven't answer whether will you want to overclock your system? As that would affect the cost and components to be gotten.
soulz81
I am not over clocking. My experience with ITX is that when I play game it get heated up haha .. Was using Lian li ITX case .
I will check your recommendation up.
singupingu
CPU+MB: Intel Core i7-7700 + MSI B250M Bazooka ($635)
RAM: Corsair Vengeance LPX 2400MHz 2x8GB ($179)
GPU: Palit Dual GTX 1070 ($535 from Lazada, stack discount codes, credit card cashback, and use Shopback for maximum discount)
SSD: OCZ TRION 150 SSD 480GB ($185)
HDD: WD BLUE 1TB HDD ($72)
PSU: Superflower Leadex Gold 650W ($169)
CHASSIS: Fractal Design Define S ($149, see if you can find non-windowed version, could be cheaper)
Total: $1924
Prices quoted from pc theme. Could add a couple more static pressure fans to the chassis to help with air flow as the provided 2x140mm fan is not the best and I don't think it's enough.
soulz81
Total: $1924
Nice setup. Let Me study it in detail
soulz81
One more question. If I get the k processor how would things change ? Is there anything I need to be careful about ? The k processor seems only about 50 sgd extra.
undead102
If you get k processor you will need to get the z mobo that can overclock the processor. This will further make the rig more expensive. Whats more you must learn how to play with overclocking to increase your pc performance I say forget it just get a non-k non overclocking build. Save the trouble.
Overclocking can increase couple more FPS difference not worth the trouble unless you are really hard core want to squeeze and want the best performance for your pc. Then go ahead and learn how to overclock and get a K processor with z mobo build to play around with. Can follow youtube guide or follow guide all around the internet on how to overclock your K processor.
Oh did not saw your previous post. If you are not overclocking don't need get K processor as it is an unlock processor for overclocking. Ii mean no point getting an unlock processor if you aren't overclocking right?
singupingu
Get k processor would incur a lot more cost. Firstly, Z series mobo, then need extra Cpu cooler as unlock core don't come with stock fan, then psu need 750w for this setup. Ram up to you whether wanna get higher hz ones for oc as it's the least gain from oc compared to processor and gpu.
soulz81
Paisley ah ask a stupid question ...7700 has base clock speed of 3.6 and 7700k is base at 4.2 right?
So can I say even if I don't get the z board I get 0.6 ghz extra?
MianBaoFren
u can say that. but no point doing that. u are spending money on things u dun need.
