Would you have recommendations on what to get if the budget is below $3k? Looking to get something that can also allow me to play triple A titles moving forward.
the 9070xt build as mentioned by tk is good enough, as faster cards like the 5080 are significantly more expensive for marginal returns in raster. but if u wish to turn on all the eye candy like path tracing, then u will want to get at least a 5070ti build.
Is the recommendations on the first post still valid or are there better options to look at now?
havent updated it in a while, u cant get the 4080s nowadays.
Hi, does anyone have any experience with buying Boxed AMD CPU from Taobao? Specifically the ones with CBX product code at the end.
I’ve been trying to research and some say it’s covered by international warranty, Some say it’s only within China.
the international warranty only covers units bought from western online etailers, china indeed has its own warranty coverage. once chatted with a carou seller who tried to claim with amd sg (which have no issue processing units bought from amz) for a cpu bought from taobao and was redirected to amd china instead. but i wouldnt worry about it, cpus generally wont need warranty and even if it does, it is very cheap (<$10) to ship it back to claim.
i got recommendations from a shop for around this price range, almost everything is the same except for these 2 items.
option1:
CPU - ryzen 7 7700
PSU - THERMALRIGHT 850W GOLD RATED PSU / ATX 3.0 / PCIE GEN 5
option2:
CPU - RYZEN 7 7800X3D
PSU - Superflower LEADEX VI Platinum PRO 850W Full Modular - PCIe 5.1 (BK)
option 2 is $400 more expensive, i'm wondering if there's a need to get the ryzen 7 7800x3d or if there are recommendations of a more worthwhile option? GPU for both is RTX 5070TI ZOTAC SOLID OC.
triple a games are generally quite gpu intensive, and if ur monitor is qhd or higher then the benefit from the 78x3d upgrade will be felt less. the psu is better with the 78x3d option though. i hope u arent paying close to 3k with either option however, 3k should be able to net u a 5080 build.
But I heard if there is no corbell sticker on the Mobo mean no warranty? Is it true? The shop told me got 3 yrs warranty.
can call corbell and check if ur mobo serial number under their warranty.
Does MSI provide repair or replacement?
typically is replacement.
