due to the nature of the game coding, it only runs efficiently on 6 cores and upon research, the cpu affinity batch coding and core affinity app does not work on the game when running on 14th gen.. i am unable to find more information thus i can only test things out on my own once i get my hands on the new rig.
that said, test have been done by a tuber indicating that disabling the e-cores will increase the game performance by 20% +/-.. and the CPU will still run at 80 to 100% on those specific cores.. and in such condition, building myself a 14700 or 14900 will not make a diff to power consumption cause tdp is still 253w.. i'm just capped by temperature..
added start:
i am actually more concern on whether the board i buying is enough for the stupid game i play cause i know the game will pull full power on 6 p-cores once i disable the e-cores.
so much of googling and can't find any concrete evidence showing different motherboard performance.. all benchmarks are done base on CPUs and all using the same maximus motherboard.. this is why i'm asking if anyone can recommend or at least educate me on how this vrms thing works and what is consider enough for 14900kf....
you see, everyone says the same thing.. gaming doesn't need so much vrms.. this that this that.. but that's in general.. in general, games don't pull 80-100% on 6 cores..
every time i start my game on my 3700x, my room feels like sauna cause my cpu is running at 65 to 70 degrees on my 360 nzxt..
:added ends
@ksrokiller @bennee
building yourself a suitable DIY really depends on what you're going to do, what performance are you expecting from the rig when playing the game on certain settings and what is your budget.
for my case, GPU is not important cause the game i play (performance wise) runs purely base on CPU.
you should do deep dive research on how the game you play works and what is important for the game, GPU, or CPU?
@bennee i suggest you put aside your money for your GPU and PSU and don't spent that..
build with 7800x3d with your current 3060 with good timing 32GB RAMs, 6400@CL32 or 7200@CL34..
decide later if you still think that the performance is not good enough.
+1 for
@deepblue_82
