diy rig, pls help a confuse lady
nur falisha
hello gents.
im a first timer in building a diy rig for work,gaming purposes such as sim4 oculus rift bf4
will need to run vpn as well as programming/terminals for work
these are my what i have in mind, i ve read a few topics so most prob will buy this all from tradepac.
i5-4440 w asus b-85 progamer
corsair airflow540
corsair rm 650 for the modular cables
2 x 4gb corsair vengence
windows 7 64bit
still cant decide between gfx
i need at leat 200gb of ssd
hdd 1tb
am i missing anything else besides moniter,keyboard,mouse?
im running on 300mbps from viewqwest
bridging the zhone ont to asus rtac68u
also most prolly the rig will need to be powered on at least 16hours a day, iam working from home
pls help to advice. tnks
nur falisha
hihi, l ve prepared around 1200-1300 without keyboard,mouse/moniter speakers
also i may send the case to be painted pink. any reco for shops that do diy paint?powercoat?
royfrosty
Im afraid painting would not be easy for that chassis. It requires a lot of time and a lot of effort to do so.
Powder coat is also not an option as the Corsair 540 AIR is made mostly of plastic. If there is a need to powder coat you will have to strip down the entire chassis in order to send in for powder coat.
ZawLee
you can put stickers all over your casing, or wallpaper to make it pink.
royfrosty
1.3k
MSI B85M G43 + i5-4460 ~ $343
GSKills ripjaws 1600mhz 2x4gb kit ~ $110
WD Blue 1tb ~ $71
Crucial MX100 256gb ~ $161
Zotac GTX750ti 2gb ~ $208
Superflower HX500 500w 80+ Gold Semi Modular PSU ~ $88
Jonsbo U3 Red ~ $119
Windows 7 Home Premium 64bit OEM ~ $110
Total ~ $1210, buy at tradepac. DIY
souler87
1.3k
WD Blue 1tb ~ $71
Jonsbo U2 Red ~ $119
jonsbo u2 red can fit matx motherboard? It is a ITX casing right?
nur falisha
1.3k
WD Blue 1tb ~ $71
hihi. can u explain to me in layman terms the diff between a i5-4440 w i5-4460? any performmance gain from this?
still no clue as what is the diff between the series of cpu. i only know got k oc seires n no k non oc series.
shadow84
Not much diff... 4460 is Haswell Refresh... I believe they just boost it by 100mhz? The rest are the same... Besides, price are the same and shops are stocking more on the 4460, so it makes more sense to get it.
tamjinhang
I know of someone who can do spray paint. adeep. Can help u arrange if required. Pink is really glaring though, so do consider.
tamjinhang
Tried to PM u but ur PM is disabled. U can Whatsapp me @ 92703205. In the meantime, I've msged the guy and waiting for his response. Hopefully he's free.
