DIY system does not boot up
wreckonize
I have a DIY system that is not booting up.
Mobo: Asus m5a99x evo r2.0
Cpu: AMD fx6300
Ram: 4 x 1600 Kingston DDR2
GPU: Asus GT740
Psu: Seasonic 650w 80+ gold
When I attempt to boot up, the CPU LED light lights up but there is no beep and the system does not boot up.
Any pro out there who can build me on what could he the possible problem?
shawntyq
Cpu: AMD fx6300
GPU: Asus GT740
not pro here but u can do few things.
do a trial and error method especially for your rams.
use 1 ram at a time and see if it runs, test each rams.
still cant then try taking out your cmos battery for 5 secs and put it back again.
gregory_choo
remove all ram , cards and hard disks.
turn it on and listen to the beeps, check with manual to find out whether the error code is correct.
then reboot with memory plugged in, again listen to error code to make sure that it is correct.
next is the grahpic card.
if ok then plug in hard disk.
you should be able to pin point the problem by going through the steps.
Rashkae
Have you connected the speaker?
Did it previously beep?
I've seen a similar issue a few times before, and it was either faulty PSU or the motherboard died (bloated cap, corrosion)
jtjt00
I have the same motherboard & cpu and have same cpu led light up one fine Saturday morning last month. Swapping cpu and other component still has cpu led light up.
Concluded motherboard dead and upgraded to Ryzen 3600 with Asrock x570 Steel Legend and 16GB DDR4 memory.
kracie17
i had that same exact motherboard, and i build for some of my friends. after few years, all came to the same problem as yours. CPU led light up. suspect that mobo has issues..
