DNS-320 Slow transfer Speed
terence52
Hi guys, Just got a Dlink DNS320. Issue is my transfer speed is really slow. I have no idea what is the problem. If I transfer files from the Nas to my pc. Its @ 6.7x mb/s. While transferring from Pc to Nas is 9.7x.
The Hdd is a Samsung F4 2TB. Router used is the Engenius ESR9850. I wonder if I did do something wrong with it. lol
Thanks,
Terence
HeeroYuy84
resolved... its a cable promblem. i was at his place, we by pass the router with a fresh cable and use the cable to connect to the router
jlim76
May i know whats the fastest method to transfer files between this NAS and PC? Possible to connect directly?
rhizopus
doh.
the N in the NAS stands for Network.
So you are supposed to connect via network.
if you want directly, why bother with NAS? just buy normal USB enclosure.
goenitz33
Thanks,
Terence
yup i am having the same issue with you.
from NAS to Notebook.
NAS to Router is Wired
Notebook is on Wireless.
On Draft N at home wonder how can i boost the speed lol...
tungsten2
yup u can connect directly using a crossed lan cable.
No need cross cable. A straight cable will also do the job well.
Looks like DNS-320 have built-in feature to auto detect connect straight or cross cable.
Good feature. Tested working.
jtjt00
I am using the same router but with Buffalo DUO NAS.
HDD used is also the same Samsung F4 2TB.
Read thread# 8 of this link:
http://forums.hardwarezone.com.sg/showthread.php?t=3459373
Thanks,
Terence
goenitz33
Then yrs is prob the wireless that is the issue not the NAS
havent exactly tested on cable but as far as i recall the results wasnt fantastic.
i shall go test it tonight also to get a clearer picture.
i was getting the same result as TS when i was moving 46GB of files from the NAS to the PC.
Router used is the Singnet 2Wire 5012NV.
My laptop's Wireless Card is on N also.
Signal loss would be minimum i reckon since my laptop is like 1m away only from the router :p
molecule
MBps or mbps? Windows PC copying shows MBps. See this chaps avg speed. Depends on file size too.
http://www.krazyworks.com/d-link-dns-320-nas-review/
Wireless even if u r next to router will be a big factor. Yes signal is great but throughput still depends. If u r perm next to router and transferring much data regularly, suggest u plug in to Ethernet
HMAN
On Engenius 9850 router with NAS DNS 320 too. with Cable on smaller file block like 1-2GB..speed is 25MBytes/sec...
on big file > 4GB per single file, getting around 15-18Mbytes/sec
On G wireless network, 2-3MBytes per sec..
On N wireless, the throughput is the most 5MBytes /sec despite the Notebook and AP next to each other
goenitz33
krazywork's results seems to be what i am getting when i am wired up.
Bro HMAN's results is what i am getting now.
looks like it is quite normal. :s13:
emoboy
Hi
I am also getting slow speeds even i am on Cat 6 cables wired at home.
Using Dlink DGL4300 wired with my NAS and Laptop. I am getting avg of 6-7MBps on the transfers.
Files that i am transfering are sizes between 300MB to 1.4GB. I have already disable FFP liao but still at this speed.
Any other solutions?? How to actually check the cable signal. I only check the port using my laptop to ensure that it is 1Gbps connection rate.
Thanks
