CPU C STATES: ENABLED - This is set to AUTO by default, change it to ENABLED and under CPU C STATES the following will appear, change as outlined:
ENHANCED C1: ENABLED
CPU C3 REPORT: ENABLED
CPU C6 REPORT: ENABLED
C6 LATENCY: SHORT
CPU C7 REPORT: ENABLE
C7 LATENCY: LONG
PACKAGE C3 STATE REPORT: C6
Using Superflower Leadex PSU 850W, not sure if it's supported?
reused my antec neo eco 450w modular psu for my haswell build
never try the power saving
dunno if supported by psu
Good timely thread.How to enable?
On typical bios settings:...
how to enable on asrock mobo?
got a guide to follow?
too bad, can't use this...![]()
