Does external soundcard improve audio quality?
lampPC
I have a pair of speakers and subswoofer connected to the PC. The sound is not as good as expected.
Does add a USB sound card help?
Currently it is using Realtek audio. Not willing to change PC because it is a AIO with 4K touchscreen.
harharhar
What is your current speakers? I think the speakers is more important than the soundcard.
GBC
Cheap sound chip will get you so so sound. If you want better sound, should invest in a better external DAC and connect your speakers to it. Another alternative is to get active speakers with built in DAC.
xonix
Depend on your ears and speaker quality.
Ferolare
a usb dac may bring some "life" into your system - still dependent on what you're using now though
mun_hoe
first level get a good decent 2.1 speaker set. not satisfied then dabble with dedicated soundcard / DAC
86technie
Yes but also depend on your speaker.
Cards like Creative X-fi surround does improve SQ.
5star_pundit
My 2.0 edifier setup
PC --> optical cable --> edifier S1000db --> HD600
________________________________________________________________
Processor
AMD Ryzen 1700X | EK-Supremacy EVO
Mainboard
MSI B350 Tomahawk Arctic
Graphics Card
MSI GTX1080 Gaming X | EK-FC1080 GTX TF6
Memory
Adata XPG Spectrix D40 2400mhz 2x8gb
Display
Acer XB271HU
Storage
WD Black NVMe 512Gb SSD
Casing
Be Quiet Dark Base Pro 900
PSU
Enermax Platimax DF Platinum 1200w
Audio
Edifier S1000db | Sound Blasterx AE-5 | Sennheiser HD600
OS
Windows 10​
tsteo77
I used to have sound quality issue on my pc, after using wall sockets instead of trail sockets, sound quality improve, it sound better than all in one hifi.
msaz
using same motherboard, sound is as “soft “ as TS deacribed. need to increase to 50-60 out of 100 to hear youtube videos clearly ( those commentary type)
bought a cheap $5-7 usb sound dongle from sim lim, need only to turn up volume around 20-25 to achieve same loudness and clearness
If TS not those audiophile type the cheap usb solution might be for TS
yusoffb01
I using swans too but the bass weakened after 6 years. you need to get subwoofers
lampPC
What about those Creative Sound Blaster Omni Surround 5.1 USB. I see some of them. Main purpose is still to improve sound clarity for YouTube videos
Godeau
Try manually tweaking your onboard soundcard software equalizer and increase dB for frequency bands 1.5k and above. Should help a little.
If that doesn't work, you can probably buy a dac like the xonar u7/mkii for a decent price and turn on Dolby home theatre, then create a custom profile that turns on dialogue enhancer levels for your youtube/movies.
shiroyuki03
using an external sound card does really improve the sound effect in terms of bass more punchy, and tuning surround sound. previously used onboard, the sound sounded crappy, lack the punch of bass and not much surround. after investing in xfi titanium, it has improved way much!
lampPC
Sound Blaster X-Fi Surround 5.1 Pro or
Sound Blaster Ommi Surround 5.1
Which one is better?
shiroyuki03
it would depend on your usage. for gaming, go for SB X-Fi Surround. For Entertainment/movie, SB Omni Surround.
Mine isnt usb. mine uses pcie.
Elysium87
im using logitech z906 already which i find the speaker very good, no point getting a sound card right for my pc?
shiroyuki03
i believe by investing a proper soundcard compared to the onboard. it will make a significant improvement! it might actually enhance your z906 even more. i wanted to get that too but no space. hence i got katana. but also got dedicated t6160.
