does higher power consumption means more heat generated?
taquito
If we have 2 2070super gfx card, one brand has only 2 fan while other brand has 3 fans. Power consumption of the 3 fan card is 25w higher than the other. Does it mean that more heat is produced when the card blows out air? Thanks!
Alphas
Yes. Of course then where does the energy goes to.
Rashkae
Chances are, the 3 card Fan has a higher clock / voltage. If you set both cards to the same settings, they will generate the same heat.
ronnie_gogs
When I was mining cyrpto currency in 2015 my room would turn into a sauna with the mining rig. Load was around 950 watts for 4 cards.
