Drobo 5D
Bought a Drobo 5D from MW last month and loaded it with 5x Hitachi 4K7000 (HDS72404, 4TB, 7200RPM) drives and a Crucial m4 128GB mSATA M4-CT128M4SSD3.
It started off promising although not fast. Benchtest (Mac OS X 10.7.5, using AJA System Tool and Diglloyd DiskTester) on the freshly formatted 5D was in the range of 190-230MB/s read and 100-130MB/s write. That kind of performance similar to eg. a pair of 7200RPM 3TB in RAID0.
My old Drobo Pro populated with 8x WD Green 3TB slowed down SIGNIFICANTLY when the drive is past 60-70% full. By slow down I mean the Drobo felt like its struggling to read and write data. Past 80%, the Drobo is practically unusable because even opening folders can take 30 seconds to respond.
Unfortunately despite the use of SSD for 'Hot Data caching', the Drobo 5D don't seem to have fixed the slowdown problem when the array fills up. Its SLIGHTLY better now, but it still gives you the frequent 15-30 sec delays just trying to navigate the folders. Reads and writes (in Activity Monitor) are now 1-2MB/s with a good amount of delay. Even my USB thumbdrive is faster and more responsive than this!
Last week just before Xmas the Drobo 5D reported a drive failure (Bay 3 light was RED
) so I replaced the Hitachi with another drive (same model/firmware). The Drobo 5D is still rebuilding with the message in Drobo Dashboard "Data Protection: In progress... estimated 7 hours". Its been rebuilding since December 24
Many reviews out there seem to be all glowing and raving about the Drobo 5D. Every review of the Drobo 5D does not seem to test and report on the performance of the 5D when its 50, 80, 90% filled. Some video websites even openly recommending the Drobo 5D ...for HD video editing! Wow. Wait till the drobo fills up and the user starts getting dropped frames.
This is just my 2ct after using a Drobo 5D for a month. Quite honestly I can't recommend this. If you had nightmares with past Drobos, the new Drobo 5D isn't going to make you sleep better. Well maybe the battery backup unit might solve some data loss issues but performance still suck ass big time. I thought Drobo might have finally gotten it right with the BBU and SSD caching, a smaller compact formfactor (its smaller than the Pegasus R4) but the same perf problems plaguing old drobos are still in the 5D and I can safely say the Mini isn't spared as well since they share the same technology.
I say save your money and wait for something else, or pay the premium for the Promise Pegasus R4/R6. My R6 is still running solid for the past 1 year and it never slows down more than 20% even at 95% capacity. Hope this helps
BTW I am a photographer and I don't work for Drobo nor Promise.
