Durable third party lightning cable for 5s?
sp0inK
Is there any apple verified and durable lightning cables out there that is 100% compatible with iPhone 5s? I carry my cable with me everyday and so it is subjected to quite a lot of abuse causing the wire to slowly break over time
rdreamer
I second Belkin. Well build.
Only thing is the lightning connector is slightly bulkier than Apple original, so if your casing fits the lightning connector snugly, it may be a problem to connect the Belkin lightning cable.
LunaSouL
Try Belkin...
I heard that Amazon also make pretty good ones.
Share share where selling at best price?
rdreamer
I bought from 2 different sites. Local from Qoo10 and while I was in China, from T-mall.
dewang86
moshi one is pretty good. cost a little more than the apple one. the plug is a little fatter which helps when u pull it out from the phone. been using mine for half a year already.
EJB
I buy from DX or Qoo10 or taobao, just buy 20-40 at one go. I only carry 1 around, 1 in office, 1 in car, 1 at home, then the rest keep for spare.
Every few months when one dies, just replace.
babywoolf
I using cygnett. Thick cable. Very durable. It cost 29.90 for 2m. Longer than the original cable :)
kenzone7
Scosche StrikeLINE pro is the best 3rd party lightning cable, with retractable mechanism for easy storage and protection of your cable. Very good build quality and available in either black or white. Only drawback is that it's a bit pricey, but if you want the best, u need to pay a bit more. Can get it from online Apple store.
iPhone Lighting Cable USB Charger | strikeLINE pro | by Scosche
oeyvind
This is pretty good as well...
NOMAD ChargeKey
