Dust Blower for Cleaning PC
EienShouko
correct me if I am wrong; the reason why people do dust blower is because even though vacuuming is idea, it produces static from the dust/dirt being sucked in which will cause problem with electronic products.
Yes, that's why it's better to use a dust blower, then use a vacuum to suck up the dust afterwards.
Can switch on a vacuum cleaner on the other side of your dust blower while you do the dusting?
Anyway with such a powerful blower, does it damage ur case fans?
Cannot.
All the dust flies up like smoke.
No way to vacuum in.
Unless you can create a blackhole to suck it.
No issues with my Case Fan, CPU Fans, GPU fans, PSU fans.
Or ever Normal Standing Desk Fan.
use compress air + normal house vacuum vs using this dust blower.
Anyone have any advice?
Hard to reach use Cotton buds? Especially GPU fans..
My satki blower clean my CPU fan + Heatsink + GPU fan + Heatsink + PSU fan
No issues at all.
The reason why people don't vaccum is because Vaccum not powerful enough to suck in the dust.
Otherwise it be so powerful that it will kiss together and you can't pull it off.
16000rpm blower sibei powerful can blow my carpet and slippers away.
abbnic
Haha, i have never open up a case to clean the inside before. Now that i build my own rig, see a need in that.
Do you plug out the parts and blow/compressed-aired them individually or just do it with everything in the case, side panels removed?
With Sexy Bosch GBL 800E, only need to open side panels.
nwh_sg
Bosch GBL 800E
Sibei satki.
SGD123.50 Only.
1 min and at least 95% of the dust in my pc casing gone liao.
Bro, where did you buy it? Tks.
nwh_sg
Don't go Home DIY they knn chop carrot head selling $138.
I bought online @ SGD123.50 with free delivery.
BOSCH BLOWER GBL-800E <---Link where I bought Online
I order on Tuesday night they deliver to me on Thursday.
Tks!
Edit: Bro, pm me your email for the Horme account so that I can input you as the referrer (you will get $5 promotion code).
koicafex
Bosch GBL 800E
http://www.boschhardware.com/wp-content/uploads/GBL800E.jpg[/IG]
Sibei satki.
SGD123.50 Only.
Tested it on my Deskfan and works efficiently as well.
[IMG]http://d2j8wlv4w10az1.cloudfront.net/assets/images/products/513306.jpg[/IG]
High Recommend it.
I try to use it like a feather duster and blow all the dust away.
Now jialat all the dust on the floor need to vaccum and mop liao.[/QUOTE]
that's why i always carry my pc out when using my datavac
the amount of dust :s22: do at home will die man lol
katoboy
Today I just borrow my friend Bosch blower to blow my entire PC Case for solid 2 minute while sing Queen song another bite for dust ouch :D now the entire case is super clean a happy man now :D
b3njaminlee
Today I just borrow my friend Bosch blower to blow my entire PC Case for solid 2 minute while sing Queen song another bite for dust ouch :D now the entire is super clean a happy man now :D
Anyone living In jurong can lent or for a small fee :o
