Dust Blower for Cleaning PC
harky
but this vacuum is not those normal vacuum le.. i think it dont really suck much stuff..
mainly i get is to blow pc dust ahaahha
harky
i bought the blower STPT600-B1
it just delivered to me.
will try on weekend...
the box actually quite small
harky
my video using Stanley Blower STPT600
ps, take wrong way
There are 6 speed control. I think I turn on level 4 speed only lol
harky
ya abit loud, so only use @ afternoon lor.. bring pc out and blow.. quite good.
Providence
I am curious though. Do you blow the CPU area/heatsink as well? Will the dust gets clogged in the CPU heatsink instead? :s11:
I used to have those air spray cans that blow dust off the PC interior but I noticed that the dust can get clogged in the empty RAM slots and the CPU heatsink easily. Then it will be a headache later.
jtjt00
Metro Datavac Blower has accessories to bend air flow at 90° for tight areas like CPU HSF.
https://www.bhphotovideo.com/c/product/599911-REG/METRO_DataVac_ED_500_DataVac_Electric_Duster_Model.html
PaLmEr-
clears all the odd corners well.
jtjt00
Any chance there's a smaller blower to recommend? =)
https://www.lazada.sg/products/metro-datavac-ed500-electric-duster-500w-220v-with-european-style-plug-not-for-use-in-the-us-intl-i208642095-s316253313.html?gclid=Cj0KCQjwgMnYBRDRARIsANC2dfnlJGpiWj7YFSjVYbkdAIXSBiRVW4X7SUIuLQwPg_JXCqE7BrmmupIaAh1XEALw_wcB&s_kwcid=AL!4281!3!219672226927!!!g!!&utm_source=google&utm_medium=sem_brand&utm_content=293946777986_316253313_120110029&utm_campaign=923429690&utm_term=47204625598_xxso0000000at0000_m_aud-362899554637:pla-293946777986&adjust_tracker=t2v78t_5n20iw&adjust_campaign=923429690&adjust_adgroup=47204625598_m_aud-362899554637:pla-293946777986&adjust_creative=293946777986_316253313_120110029&tracker_limit=1000000&ef_id=WEGgHgAAAeALO7cU:20180603045744:s
