Early 2011 MacBook Pro, Battery Bloated
  • Need someone to talk to?
bluemint
My MBP's AppleCare warranty just ran out.
Shortly before that, I noticed the Trackpad is hard to depress. Since I seldom use the MBP, I ignore the defect and continue to use my Mouse to navigate instead.
Just after the AppleCare has expired, I find the Trackpad cannot be depressed unless using a lot of force. A quick Google search reveals the battery must have be bloated.
So I open up the MBP to check and sure enough, the Trackpad is fine but the Battery seating directly underneath has bloated to the point the Trackpad cannot be depressed.
My questions are... can I go claim AppleCare now?
If not, where can I get a replacement battery at a good price?
Thank you for any advise.
Here are some stats on the Battery. Is it in good condition?
Charge Information:
Charge Remaining (mAh): 4687
Fully Charged: Yes
Charging: No
Full Charge Capacity (mAh): 4766
Health Information:
Cycle Count: 94
Condition: Normal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 12415
ykeen
Moderator
Moderator
Can try talk nicely to Apple if just over few days and try to appeal see if they are ok. Else you have to self replace or find outside shops.
B772ER
Give AppleCare a call and ask nicely if they are able to give a repair exception since your APP just ran out. Don't go about demanding it and hopefully there would be a positive outcome out of it.
chehjin
just call and try ur luck.
but dun worry, this thing can replace on your own very easily and its not expensive
kraze
Any idea how much is battery replacement?
I also have the same battery bloating issue with my 2011 MBP which only surface recently. However, I dont have any applecare. :(
chehjin
the last time i bought the part for mbp 2009, it was $65, should be about that price.
bought from sim lim. ebay can be cheaper by a few dollars. up to you
squeeish
There's a battery shop at Sim Lim Square second level, near the adult toy shop. I bought a battery from there for my family's macbook.
normanho23
Thank you everyone for your advises.
I will try to talk to AppleCare about it.
I found this site selling compatible battery for $75.
Replacement for APPLE MacBook Pro 13' A1322 Series Laptop Battery
Has anyone bought from the before?
Brand new genuine Apple battery should have between 5600-5800mah. The one that the shop is selling is a compatible battery with just 4200mah (about 26% lower capacity). I do not recommend anyone to get compatible battery for Apple Macbook coz compatible cells tend to have lower cell count and cycle life.
chehjin
i believe this is the same shop I went to. Battery,batteries,battery charger,notebook battery
personally, for this item, unless its nearer half price, i will get it locally, so that if anything happens, its easier to resolve.
