Earphone Review: Battle of sub $80 in-ears earphones plus others!
99heyho
Anybody can recommend earphones.
Less than 80
Good bass
Preferably one of the more established Japanese brands like audio tec, Sony, nakamichi
Meant for a gift. Help Please. Thank you
notaniceguy98
Rig: Xperia Z3
Type of music : pop and rock
(I'm looking for a more balanced sound not very bass heavy)
Price range: 60-80
I had an Ajays One before until i lost it recently so any suggestions?
enzo_tan89
Rig: Xperia Z3
Price range: 60-80
You can check out HiFiMan's RE-400. Although they will cost you about $120 including shipping, it will be one of the best in its class that you can ever find. In my opinion, it can rival earphones twice its price
peterg
My Audio Technica IM70 just dead after only 1 and a half year.. :(
Looking for a replacement for this, an upgrade may be..
Budget $150-200, any recommendation guys?
Takechan
Hi, I'm exploring alternatives to retire my damaged Monster Turbine Pro Copper IEMs (still working, but has exposed wires near the tip)
- Your rig: LG G3
- What type of usage: 75% Music, 25% everything else
- File format used in your source: flac, mp3, Spotify (Highest quality)
- Genre of music you listen to: Mainly Japanese and English pop & rock
- Headphone / earphone type: IEM
- Other requirements (if any): Warm; deep and tight bass preferred
- Budget : <SGD 400 (open to choices from Amazon as well)
My IEM has lifetime warranty but just feeling backside itch to try something else.
Jason8811
- Your rig: LG G3
You can audition the Mee Pinnacle P1 or the JVC woodies FX-750, both under your budget and can try before you commit.
hpv500
Hi guys, any recommendations for earphones that will meet the below needs. Thanks
- rig: Sony Z3 TC
- What type of usage: music only
- File format used in your source: MP3
- Genre of music you listen to: music with good bass. clubbing songs, SQ songs
- Headphone / earphone type: in-ear / on ear
- Other requirements (if any): bassy / SQ combi if possible
- Budget (in figures): $200+-
dancingqueen
- rig: Sony Z3 TC
Sounds like the Vmoda ZN suits you.
http://v-moda.com/zn/
generalpaper
- rig: IPhone6
- What type of usage: Music only
- Genre of music you listen to: EDM, House, basically clubbing music with bass.
- Headphone / earphone type: in-ear , wireless
- Other requirements (if any): , small compact, can put in pockets
- Budget (in figures): 100-200$
cheers
Jason8811
- rig: IPhone6
cheers
VModa ZN works great for your requirement. They have great built and very suitable for the music you listen to. http://www.stereo.com.sg/shop/earphones/in-ear/v-moda-zn.html
q w e r t ii
Hi looking for decent noise cancelling earphones
rig: IPhone6
- What type of usage: Music, movies
- Headphone / earphone type: in-ear, headphones (wired)
- Budget (in figures): $70-100
musicdreamer
rig: IPhone6
Budget abit low..better ones are at least $300++..Audio Technica ATH-ANC33iS should be decent enuff in your range.
q w e r t ii
Yea low budget because i will only be using once or twice a year... Sitting c130 this september so i thought of getting one so i can use it to dampen out somee engine noise :D
Benajmin
rig: IPhone6
Hi, i can recommend A-Jays 4+, which has great bass for EDM music. It's cost around 100 la but if you re looking for cheaper ones, a-Jays one are great too:s13:
hehuafa
Any one knows about pholips SHE3590 in ear noise cancellation ear phone ?
Heard its cheap but really good based on reviews.
redarowana_rs5
- rig: PC
- File format used in your source: MP3,Flacs,Wav
- Genre of music you listen to: pop (K,J,chinese,canto,international), Soul, EDM
- Budget (in figures):100-150
Personally prefer have higher fidelity than bass. Dont like to have too much bass.
Currently using Soul SL 49, the gold platted L jack starting to "fade" earphones will have static sound when i move it :(
