Earpiece jack to audio + mic jack
As I do not wish to purchase a microphone or a headset, is there an audio cable that allows me to utilise my earphone's (AJAYS) microphone?
Its the opposite of the picture above, earphone jack to audio input + microphone input on desktop. Any ideas/suggestions guys?
ondooy
plug in your cable, select the correct jack as your recording device...
you should now be able to use your earphone's mic...
As in what I have is similar to this, and I want to plug in my AJAYS and use it as an audio + recording device. In other words, I want to utilise my AJAYS microphone as well. And since AJAYS only has 1 earphone jack, how to I achieve this? Is there any external cables that are available?
haodede
Suspended
I believe you are looking for something like this > list.qoo10.sg/item/MAELINE-3-5MM-FEMALE-TO-2-MALE/422439355
Alphas
Yes there are those that split the mic and phones to each connector
kandinsky
devilwahaha
Then just get the above cable but in reverse gender? Male on the green/pink and female on the single 3.5mm.
