Easy switching between speaker and headphone
zjlim86
is there such thing as above? currently have speaker and headphone..and i have to exchange the plug whenever i wan to switch. if have, can recommend the place to buy and the price? thank!
onimenokyo
Not sure of a switcher but SLS sells splitter which means 1 port split into 2 ports. Bought it long time ago not sure which shop sorry.
bhtan83
Plug ur speaker at the back and headphone at the front port?
Teng Zai
This.
Unless you do not want to use the front port(or back port) because of static interference, consider a sound card with multiple 3.5mm/rca for your speaker and headphones.
An external USB Dac such as the Xonar U7 will fit your needs, but priced at $130+, you can plug both headphone and speaker in it, and when you press down the volume button, it will switch between speaker and headphones instantly.
xxvii27
This.
Where can we get the Xonar U7?
We connect the USB and SPDIF from the PC to the Xonar U7 and the 3.5mm cable from the Xonar U7 to our speakers? Very interested in Xonar U7! :s13:
