wwenze
- Dec 2, 2002
In Singapore its currently SGD $259 vs $639; both currently 10% off, but in USA it is USD $249 vs $399
So already we are paying too much for Audioengine here...
That aside,
The closest I had to an Audioengine A5+ is a passive Audioengine A5... and people on the internet say they sound the same, so if we can take their word...
Each's weakness is the other's strong point - A5 is weak in bass (and both sides of frequency extension actually) while R2000DB is strong, but A5's mid and overall sound is very good. Some have commented it is slightly mid-heavy and I may have to agree, but that is nothing wrong because I own both warm speakers and dry speakers and they both have people who think they are "neutral".
With the A5, I couldn't find anything wrong with the sound. Yea, if you compare it against other $500 speakers (It wasn't priced at $700 back then) you will find other speakers do things that are expected of speakers of this price range better. But if you upgraded from cheaper products to A5, it is hard to find anything where A5 is inferior. Yea if you went from 2.1 to A5 you will find the lack of bass very obvious, but you can still live with it; it's the kind of sound that can be accepted very easily.
Overall I would consider A5 (and by induction, A5+) as a better speaker; first impressions it wins, if both are given EQ A5 is likely to win, the only loss is probably the bass because it is hard to increase bass without causing lots of things to screw up.
But, they are very close, especially if you consider how good R2000DB's bass is. Close enough to let personal preference decide.
If you came from dry or bright speakers (*cough*Soundsticks*cough*), you may prefer R2000DB's sound. If you came from 2.1, you will appreciate R2000DB's bass. If you came from 2.0, well 2.0 has dry and warm ones too, then A5 is good. (I think it is more neutral than warm, but my neutral seems to be warm to other people so...)
That aside,
In simple layman term, a external DAC is good or bad. Will this improve on the performance of the R2000DB?
